20 Most Recent
Mr. Heater Portable Propane Forced Air Heater - 35,000 BTU Questions & Answers
My mr. Heater lights only stays lit for about 3 minutes and then it goes out
I had this same problem with my heater. I cleaned the propane tube where the flame comes out (after it’s off and cooled down) with a Qtip and some alcohol. After removing some cotton, it will fit all the way down to the end of the tube. Repeat until it comes out clean and stays lit. I had to repeat with 91% rubbing alcohol and more Qtips, and most of the cotton removed.
How do i disable the oxygen sensor on a mr buddy heater
The responses so far I don't believe are answering the question. Instead, they are mentioning potential problems not related to the question.
The Mr Buddy propane heater has a sensor which detects the amount of oxygen/fresh air in the area being heated. If the amount of fresh air/oxygen is too low, the sensor will shut off the propane flow to the pilot light and burner. The question is asking, how to bypass/disable the sensor.
