20 Most Recent
Soleus KFR-18GW Split System Air Conditioner Questions & Answers
I need a fan propeller
Yes the propeller of many units are similar and sometimes identical even from deferent brand and models. The most important parameter is the diameter of the propeller.
Need Replacement filters for Soleus R150
If you need replacement filters for your Soleus R150 air purifier, you can try the following steps:
- Check the user manual: The user manual for your Soleus R150 air purifier should provide information on which type of replacement filters are compatible with your device. Check the manual to find out which filters you need to purchase.
- Contact the manufacturer: Reach out to the manufacturer of the air purifier to inquire about replacement filters. They may be able to provide you with the filters you need or direct you to a retailer that carries them.
- Check online retailers: Many online retailers sell replacement filters for air purifiers, including Amazon, Walmart, and Best Buy. Check these retailers to see if they carry the filters you need.
- Visit a local retailer: You may be able to find replacement filters for your Soleus R150 air purifier at a local home goods store or home improvement store. Check these retailers to see if they carry the filters you need.
When purchasing replacement filters for your air purifier, be sure to check that they are compatible with your specific model of air purifier. It is also important to follow the manufacturer's instructions for replacing the filters to ensure that they are installed correctly and functioning properly.
