20 Most Recent Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Questions & Answers
As with all appliances. When in doubt turn off the main breaker to your hob. Wait 20 seconds. This might fix it. Next try a different element. Some of the ranges require you to turn the breaker on with cook top covered. If it still has problems try changing your frying pan.
Buy it from a repeatable store so you can return it if it is not the pans. Lastly. Try moving it in the surface as it will click until it finds the pan. Good luck.
Stoves Sterling... | Answered on Feb 28, 2015
Some times the pots that you may be using are not designed for use in induction cooking. If you are, It might be the size of pot. The peeping sound might be the cook top looking for the pot. But when all else fails. Turn the stove off at the Breaker count to 12. Turn back on. Reboot. Hope one of these work.
Stoves Sterling... | Answered on Nov 20, 2014
Hello & Welcome to FixYa
The clicking can only be stopped after replacing the igniter, if it tests fine then it means that the spark module is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Stoves Sterling... | Answered on Jan 25, 2012
Had some problem. Point a hairdryer at the top vent just below the control panel. There's a circuit board on top with a dodgy heat sensor. With the oven on get it hot enough and it will come back to life. Take out the oven and open the top and point the hair dryer right at it if the vent isn't working.
Stoves Sterling... | Answered on Dec 16, 2011
assets.glendimplex.com.au/.../444447973_STOVES_Sterling_1100DF-A_SML.pdf
Stoves Sterling... | Answered on May 26, 2011
Hi
You have to remove the old one first by disconnecting the wire teminals and the fixing screws. Remember to disconnect the power before starting work,
You can get the parts from www.pcappliancerepair.com/whirlpool-range-oven.php
Hope this gets you sorted.
Stoves Sterling... | Answered on Oct 21, 2008
All electric stoves I have ever worked on have fuses for the elements, oven and 120v power outlet
Stoves Kitchen... | Answered on Oct 11, 2019
we are in USA, so asking here will be slow or zero.
give that fact
Stoves Kitchen... | Answered on Jun 27, 2019
Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Logo
28 questions posted
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Ned Halaweh
Ned Halaweh
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Stoves Kitchen Ranges
Most Popular Question
please e mail
  • Kitchen Ranges
