20 Most Recent
Grundig GDDP-485 Questions & Answers
Problem with the DVD Player
if your set is new and on warranty then it is advisable to take it back to the dealer you bought it from.if the warranty is done then you will have take it to a repair shop your problem is in the video section the video chip could be defected.
Hello !! Friends i need to know how to remove key lock from grundig tv model gu26dvd. .with out using a remote control. Thanks
Hello! I'd be happy to help you.
To remove the key lock from your Grundig TV model GU26DVD without a remote control, you can try the following steps:
- Turn on the TV using the power button on the TV itself.
- Press and hold the MENU button on the TV for several seconds until the menu appears.
- Use the volume up/down buttons to navigate to the "Lock" or "Child Lock" option and press the MENU button to select it.
- Enter the four-digit password using the number buttons on the TV. If you don't know the password, you may be able to find it in the TV manual or by contacting the manufacturer.
- Navigate to the "Off" option and press the MENU button to select it.
- Press the MENU button to exit the menu.
If the above steps don't work or you don't have the manual to find the password, you may need to contact the manufacturer or a professional technician for assistance.
3/4/2023 7:25:58 AM •
Grundig...
Answered
on Mar 04, 2023
How to change or reset pin code on Grundig TV 32 GEH 6600B
Hello Petar,
To reset the pin code on your Grundig TV 32 GEH 6600B, you can try the following steps:
- Turn on your TV and press the "Menu" button on your remote control.
- Navigate to "Settings" and then select "Child lock" or "Parental control."
- Enter the current pin code (if you know it) using the number buttons on your remote control. If you don't know the pin code, try entering "0000" or "1234".
- Once you are in the parental control menu, select "Reset" or "Clear all" to reset the pin code.
- Confirm that you want to reset the pin code by entering "Yes" or pressing the OK button on your remote control.
If this does not work, you may need to consult the user manual for your specific TV model or contact the manufacturer for further assistance.
I hope this helps!
3/4/2023 7:22:39 AM •
Grundig...
Answered
on Mar 04, 2023
GRUNDIG 50 vle 932 bh won't boot
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location...
9/15/2021 10:57:26 AM •
Grundig...
Answered
on Sep 15, 2021
I have universal Remote YA9-000146 and need code for grundig tv
Remote Control Codes For Grundig TVsGrundig 3 Digit TV Remote Codes113110128Grundig 4 Digit TV Remote Codes019501600161017103100320114411241131Grundig multi-brand remote codes instructions for TV's.1 - Turn on TV.2 - Press and hold the TV key and enter the codes for your brand.3 - If your TV turned off then you entered the right code and setup is complete. repeat with next code if needed.
4/30/2021 7:59:46 PM •
Grundig...
Answered
on Apr 30, 2021
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
3/16/2021 9:17:21 AM •
Grundig...
Answered
on Mar 16, 2021
Grundig tv unlock code please help
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock to many popular brand TVs are given.
Search the site by type in the
"Brand Name" (Exclude the model number) to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
2/24/2019 5:21:28 PM •
Grundig...
Answered
on Feb 24, 2019
Menu keeps flashing on screen
It seems to be any button of your remote control or of TV has gone sticky. To rectify remove cell from remote and ON/Off your TV manually. If it appears again,check all buttons on TV pannel, there may be any button sticky.
Hope it will short out the problem.
2/3/2019 1:51:22 AM •
Grundig...
Answered
on Feb 03, 2019
