20 Most Recent Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb Questions & Answers
USB flash devices don't need drivers. I believe you might have removed one or both of these drives from the PC without using the proper procedure, and the PC (or notebook) is now "confused". Re-attach one or both devices, but this time, either use (Windows) Explorer to "electronicaly" eject the device (right click, then choose eject) or use "Safely Remove Device" shortcut, usually on the bottom right=hand corner of your screen (the taskbar).
Lexar Media... | Answered on Sep 11, 2017
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Lexar Media... | Answered on Dec 11, 2013
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
Sounds like you need a simple reactivation. Try the link and article below. You should probably skip the uninstall instructions.
http://downloadgames.support.pogo.com/link/portal/5400/5799/Article/1805/How-can-I-install-or-reinstall-my-Pogo-Download-Games-Center-game
Computers &... | Answered 3 minutes ago
https://www.adobe.com/support/flashplayer/downloads.html
Download the latest free Adobe flash player its free. Java has nothing to do with adobe .
If java is out of date it can be downloaded or updated for free also . But I did have an issue with the latest release of Java not working with Netdania charts. Had to use the past previous later version to get java to work.
https://www.java.com/en/download/help/java_update.xml
Reason is Pago would have updated it's website to run with the latest Adobe flash player or Java.
Computers &... | Answered 4 minutes ago
Pogo Support: 1-408-763-5761
Pogo Support: 1-408-763-5761 #pogo support number,
Pogo Support: 1-408-763-5761 #contact pogo support,
Pogo Support: 1-408-763-5761 #pogo customer support number,
Pogo Support: 1-408-763-5761 #pogo technical support number,
Pogo Support: 1-408-763-5761 #pogo technical support phone number,
Pogo Support: 1-408-763-5761 #pogo tech support phone number,
Pogo Support: 1-408-763-5761 #pogo customer service live chat,
Pogo Support: 1-408-763-5761 #pogo tech support number,
Pogo Support: 1-408-763-5761 #pogo customer care
Pogo Support: 1-408-763-5761 #pogo help
Pogo Support: 1-408-763-5761 #pogo#Help#pogo tollfree number
Computers &... | Answered 6 minutes ago
Sure, no problem. We at Fixya don't mind if you do that.
Computers &... | Answered 7 minutes ago
Computers &... | Answered 8 minutes ago
Make sure that you have installed all software updates for the tablet and apps.
Computers &... | Answered 9 minutes ago
Computers &... | Answered 10 minutes ago
#pogo support
#pogo customer care
#pogo help
#pogo#Help
Computers &... | Answered 15 minutes ago
#pogo support
#pogo customer care
#pogo help
Computers &... | Answered 16 minutes ago
Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb Logo
2 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Harrie
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
lexar 16gb s73 appears as innostor nand
  • Computers & Internet
