20 Most Recent Lexar 8GB JumpDrive TwistTurn - USB Flash Drive - Hi-Speed USB - Blue Questions & Answers
Hi Sarah... We will need to know a few more specifics before any information can be given to you. What program where you in, and what type of document were you trying to save. If you were in Microsoft Word, you can go up to the "file" menu, and look for "recent items". At that point, you would be able to open the document that you were working on, and then save it to your location of choice. What you might find simpler in the future, is to simply save documents to your desktop, and then drag them to the flash drive directly from there. At that point, you will have the document both on your desktop and the flash drive, and you can then take the documents it is still on your desktop, and move it into your documents folder...
Lexar 8GB... | Answered on Jun 21, 2014
If it shows up as a drive letter try formatting it.
Lexar 8GB... | Answered on Jan 11, 2014
The thumb drive you have came already formatted and ready to use. It will read as a DISK because it works the same as a CD or DVD disc. A formatted flash drive is set up at the factory and ready to be used by the new owner. Just copy what you want to move from the computer to the flash drive. When you want to remove data from the flash drive, simply DELETE doing the same as you would on your computer PC or Laptop.
Lexar 8GB... | Answered on Dec 19, 2013
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
That's a bit cryptic, but looks to be something in a foreign language? We only speak English in this North American Fixya website. We need your make model and what it is plus a full description of what the problem is and what you have tried.
https://www.google.com/search?q=Inte+dator+stereo
Computers &... | Answered 5 hours ago
Hi guys I have a problem with Celestion C6-S subwoofer.
I guess the nature of the problem is a secret. Thanks for dropping by anyway :>)
Computers &... | Answered 10 hours ago
If you have all the latest updates to Outlook, drag a folder from Outlook to your desktop and it will export as an mbox file which you can then import into Mail. To get your contacts and calendards into the OS X applications, go to Sync Services under the Tools menu in Outlook and select to sync the contacts and calendar.
Or you can simply look for third party tools for better and fast results, here is one recommended by apple store:
https://itunes.apple.com/in/app/olm-converter-pro/id522796199?mt=12
Regards.
Computers &... | Answered 23 hours ago
Important: If your PC is producing pptd40nt.exe errors, you should check your Windows operating system immediately! The file pptd40nt.exe is part of the program ScanSoft PaperPort from the manufacturer ScanSoft. Its task: pptd40nt.exe allows you to organize all documents in an application.
http://www.process-information.net/us/pptd40nt-exe.htm
http://speedutilities.com/error/pptd40nt.exe.html
Computers &... | Answered Yesterday
Windows 10:
  1. While on the screen where the error appears, press Shift+F10 to bring up the command prompt.
  2. Type CD x:\windows\system32\oobe (with x being the drive letter where Windows is installed, for example c:\windows\system32\oobe)and hit Enter.
  3. Type msoobe and hit Enter.
https://www.dell.com/support/article/en-pk/sln293812/windows-setup-could-not-configure-to-run-on-this-computer-s-hardware-error-during-windows-7-or-windows-10-installation?lang=en
https://www.youtube.com/watch?v=_yUgRYHv7UI
Lexar 8GB JumpDrive TwistTurn - USB Flash Drive - Hi-Speed USB - Blue Logo
7 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Harrie
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
get document back from lexar 8gb
  • Computers & Internet
