20 Most Recent Lexar JumpDrive S73 - USB flash drive - 16 GB Questions & Answers
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Lexar JumpDrive... | Answered on Dec 22, 2013
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Lexar JumpDrive... | Answered on Jan 30, 2013
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
Make and model of computer may help you get an answer
Computers &... | Answered Yesterday
What laptop?
What Operating System?
In windowss you can use the "Print Screen" function by pressing the "PrtScn" key on an extended keyboard. If you hold the "Alt"-key while pressing the PrtScn-key, it takes a snapshot of the currently active window.
Then you have to open a paint or Word document. Now you can paste the screenshot.
If you use Windows 7, click the Start button and type "Snipping Tool". This will start the built-in screenshot software.
Computers &... | Answered 2 days ago
delete my account
Lamar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
We are FIXYA dot com.
We are probably not who you think we are.
We don't send emails.
Could you please email a compressed version of the whole disk content and I will send you instructions for free on how to do it, I will need to see the software to come up with how to.
Please email me i on:
[email protected]
Thanks
Computers &... | Answered 3 days ago
Replace the optical drive.
We are NOT who you think we are.
You didn't order from us.
We don't sell anything.
We only give information.
South Africans have NO idea where they post on the Internet!
o overcome his error do the following.
  1. Go to Start then Run menu.
  2. Type MSCONFIG and press enter
  3. Under the 'BOOT' tab, tick the 'Safe Boot' box and select 'Minimal'
  4. Press OK and proceed to restarting the computer when prompted
  5. Once computer restarts log in and open Window Explorer
  6. Navigate to your Windows directory and look for SoftwareDistribution folder
  7. Rename this folder to SoftwareDistribution.old
  8. Go back into MSCONFIG and turn off 'Safe Boot' and restart
  9. Run Windows update again.
Good Luck!
Computers &... | Answered on Jul 30, 2020
Error Code 0xc0000185 is caused by a corruption of data related to the boot purpose of a Windows PC. Certain files have been deleted or damaged in some way, or something as innocuous as a faulty shutdown or a new peripheral is throwing a spanner in the works.
1. Reboot the computer.
2.Rebuild the BCD
3. Rebuild the BCD with boot media.
4. Execute a system restore.
5. Format the partition and reinstall Windows.
Here is a way to fix any errors in Printer & Computer.
FULL SOLUTION WITH EXPERT NUMBER- Error Code 0xc0000185
Lexar JumpDrive S73 - USB flash drive - 16 GB Logo
2 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Harrie
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
cannot format s73 jumpdrive
  • Computers & Internet
