20 Most Recent Lexar JumpDrive S70 - USB flash drive - 8 GB Questions & Answers
Plug it in to a usb port.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver Example on how to copy data and download and save it to usb drive Click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive Click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps.
Lexar JumpDrive... | Answered on Dec 12, 2012
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Lexar JumpDrive... | Answered on Aug 20, 2012
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Lexar JumpDrive... | Answered on Aug 14, 2012
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
https://www.youtube.com/watch?v=22PIHvwZJ-I
Computers &... | Answered 1 hour ago
Hi guys I have a problem with Celestion C6-S subwoofer.
I guess the nature of the problem is a secret. Thanks for dropping by anyway :>)
Computers &... | Answered 20 hours ago
If you have all the latest updates to Outlook, drag a folder from Outlook to your desktop and it will export as an mbox file which you can then import into Mail. To get your contacts and calendards into the OS X applications, go to Sync Services under the Tools menu in Outlook and select to sync the contacts and calendar.
Or you can simply look for third party tools for better and fast results, here is one recommended by apple store:
https://itunes.apple.com/in/app/olm-converter-pro/id522796199?mt=12
Regards.
Computers &... | Answered Yesterday
Important: If your PC is producing pptd40nt.exe errors, you should check your Windows operating system immediately! The file pptd40nt.exe is part of the program ScanSoft PaperPort from the manufacturer ScanSoft. Its task: pptd40nt.exe allows you to organize all documents in an application.
http://www.process-information.net/us/pptd40nt-exe.htm
http://speedutilities.com/error/pptd40nt.exe.html
Windows 10:
  1. While on the screen where the error appears, press Shift+F10 to bring up the command prompt.
  2. Type CD x:\windows\system32\oobe (with x being the drive letter where Windows is installed, for example c:\windows\system32\oobe)and hit Enter.
  3. Type msoobe and hit Enter.
https://www.dell.com/support/article/en-pk/sln293812/windows-setup-could-not-configure-to-run-on-this-computer-s-hardware-error-during-windows-7-or-windows-10-installation?lang=en
https://www.youtube.com/watch?v=_yUgRYHv7UI
Lexar JumpDrive S70 - USB flash drive - 8 GB Logo
8 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Harrie
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
use lexar jumpdrive computer
  • Computers & Internet
