20 Most Recent Innovage 69420210126 Phone Questions & Answers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Innovage... | Answered on Oct 25, 2016
areacode 416 is in the following locations:
East York, ON
Etobicoke, ON
North York, ON
Scarborough, ON
Toronto, ON
York, ON
Innovage... | Answered on Sep 04, 2014
whould u like me to help in teach mirror stich embroidery
Innovage... | Answered on Feb 27, 2010
Do you have cable for your phone service? I had the same problem, called the cable company and they switched the cable box in my house. Problem solved.
Innovage... | Answered on Jan 07, 2010
Yes these phone's are sensitive to the phone jack its plugged into as it powers the backlight and the whole phone itself. You need to check and see at the NID Network Interface device outside and check and see how much voltage you got comming in there. This is a problem too with the phone is if you have more then two phones in the house on this NID, Trust me I have this phone and it is verry sensitive and it requires poer to run the unit this is a factory issue as well they built these phones without thinking about the customers situation.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Innovage... | Answered on May 21, 2009
Dear lowis
Check weather it requires an external power, if it requires then u need to supply it, else if it doesnt require an external power then it is the settings at the subscriber end, which we can not do anything unless we request or complain them. And it is not the fault with the instrument. But note that the instrument mechanism could be designed with a low amplification which means it has poor circuit.
Innovage... | Answered on Apr 25, 2009
THERE IS A BLOCKING FEATURE IN THE MANUAL ON PHONES ON THE SAME LINE ,FIND IT READ IT MAYBE THIS WILL HELP
Innovage... | Answered on Mar 23, 2009
Cnavarro,
my existing phones work fine but the new phone is really weird. tested Ok at the supplier's store and perfect at my friends' houses. But once tested at any of the phone outlet in my house, after keying the first 3 numbers....PLEASE CHECK YOUR NUMBER AND DIAL AGAIN etc... the scenario telling me my phone service in my house is OK and the new phone tested OK at other locations.
See if you could give me some clues....thanks
DS Max USA, Inc. Contact Info 19511 Pauling Foothill Ranch California 92610 Phone: 949-587-9207 Fax: 949-587-9024
Innovage... | Answered on Mar 01, 2009
Just push delete while using to shuffle through volume levels. Chances are it's just a bad phone and is already on top volume (level 4).
Innovage... | Answered on Feb 08, 2009
it won't work
Innovage... | Answered on Aug 30, 2008
I don't know whay I did sorry, but it now works. I was going thru different functions and when I tried again it workd. I jist noticed when it dials out it makes the old fashioned rotary dialing sound after ea number selected. I'm just glad it works.
Also it is not compatible with the home phone features of my service provider like *98 to access msgs.
Thanks, I look forward to using the Christmas ringtone!\
Cathy
Innovage... | Answered on Aug 22, 2008
If anyone still needs the manual / guide for this phone, I have posted it at http://www.esnips.com/web/pubdocs It is only one page. I should remain there indefinitely. Cheers.
Innovage... | Answered on Jul 16, 2008
werascal: It can be done. First look at the appliance body to see if there is a power jack. If not and your a tech type person you can do this: I assume the batteries are in series, if so their total sum equals 4.5 volts. You can direct wire your supply to the battery string ends, polarity observed correct with a supply voltage of 4.5 and bingo no need for batteries. Thanks for the question. Jerry
Innovage... | Answered on Apr 18, 2008
My phone did the same thing. It was the spy prevevtion function. pressing (#) for over 2 seconds. turned "SPI OFF". worked OK.
Innovage... | Answered on Apr 09, 2008
Innovage 69420210126 Phone Logo
36 questions posted
Top Innovage Lands Phones Experts
ray gallant
Tom Chichester
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Innovage Lands Phones
Most Popular Question
area code 416
  • Lands Phones
