20 Most Recent Maxtor DiamondMax 80 (96147H6) 61.4 GB Hard Drive Questions & Answers
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
9/2/2009 6:39:38 PM • Maxtor... • Answered on Sep 02, 2009
My maxtor external hard drive gives out an alarm sound when plugged in what is wrong?
You may have damaged the heads in the drive
8/22/2014 2:11:53 AM • Maxtor... • Answered on Aug 22, 2014
Hard drive not readable
You can try it on another computer but I expect you will need data recovery help. I can suggest http://FreeDataRecovery.us
8/24/2012 8:26:54 PM • Maxtor... • Answered on Aug 24, 2012
Need maxtor Diamond 21 320 gb slave setting
Take a look at this pdf:eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdfSo If this is layout " : : : . : " then...slave ----------- " : : : . : " master -------- " [:]: : . : "cable select -- " :[:]: . : "6_24_2012_10_44_02_am.gif
6/24/2012 10:44:20 AM • Maxtor... • Answered on Jun 24, 2012
2answers
Setup cannot acces this disk
Do you have the jumpers set correctly for your setup? Check it against the diagrams on this pdf:http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
6/20/2012 5:02:31 AM • Maxtor... • Answered on Jun 20, 2012
6E040lo error code CA699178
are you sure this is the error code ca699178 ?click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope this helps you
3/24/2012 6:18:11 PM • Maxtor... • Answered on Mar 24, 2012
Hard drive clicking
your las hope is to replace the Pcb Controller with a working and exact same one ,
2/9/2012 1:45:01 AM • Maxtor... • Answered on Feb 09, 2012
Maxtor 3200 manual for Mac
Link 1 https://drive.google.com/file/d/1ec_BG1BrTXhPWyMgJtbfMAAmrV1lrTY7/view?usp=share_link Link 2https://drive.google.com/file/d/1Wni-u68YQaeCs7eMNhgIEeUgg1fRUO0Q/view?usp=share_link
1/10/2023 4:33:14 PM • Maxtor Computers... • Answered on Jan 10, 2023
2answers
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
10/26/2021 10:57:06 PM • Maxtor Computers... • Answered on Oct 26, 2021
Where can I download the drivers for Maxtor Diamond max plus 9 120gb ata/133 HDD
I doubt they are still available but usually one can be found on the maxtor web site, (many years ago).
6/26/2021 3:51:04 AM • Maxtor Computers... • Answered on Jun 26, 2021
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
12/23/2017 10:06:22 PM • Maxtor Computers... • Answered on Dec 23, 2017
My Maxtor M3 is showing titles of documents stored from my former office PC but the files will not open on my laptop, other than those with attachments in PDF format, which do open
The application that was used to create those files is not in your laptop. Ergo, they cannot be read.
8/19/2017 3:56:23 PM • Maxtor Computers... • Answered on Aug 19, 2017
Maxtor DiamondMax 80 (96147H6) 61.4 GB Hard Drive Logo
Popular Tags
1 questions posted
Top Maxtor Computers & Internet Experts
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DiamondMax Maxtor
  • DiamondMax Maxtor
Most Popular Question
jumper settings maxtor n256 master slave
  • Computers & Internet
