20 Most Recent
Neon Light, CCFL COLD CATHODE LIGHT KIT 30CM/S/BLUE Questions & Answers
Neon light only comes on for a second. What is the
investigate all soldering on printed circuit board and check for bad (swollen) electrolytic filter capacitors. May need large magnifying glass or low power(5x to 20x) inspection microscope to find hairline thin fractured thermally intermittant solder connections of electronic component leads to foil trace circuitry!! good luck with the hunt! 12fixlouie
The car keeps over heating ,going thru at least
The engine is leaking cooant some where and it is a big leak.
Could be from a cracked radiator or heating hose, or a leaky radiator, or radiator cap or into the oil sump, this will cause the oil to change to a milky color. It could also leak coolant into the combustion chamber pass a faulty head gasket.
Fill the radiator and put the car in park and run the engine until it reaches running tempurature, open the bonnet and look around the engine and under the car to see where the coolant is leaking. Also have a look at the exhaust tail pipe and the oil dip stick for color changes to the oil.
My car is overheating. I have changed the
Disconnect the negative battery cable.
Raise and safely support the vehicle. Remove the right inner splash shield.
Remove the accessory drive belts and power steering pump.
Drain the cooling system into a suitable container.
Securely support the engine from the bottom, then remove the right engine mount.
Remove the power steering pump bracket bolts, then set the pump
and bracket assembly aside, but the power steering lines do not need to
be disconnected.
Remove the right engine mount bracket.
Remove the timing belt tensioner and timing belt
Remove the camshaft sprocket(s) and inner timing belt cover
Unfasten the water pump-to-engine attaching screws, then remove the water pump from the engine.
- Remove and discard the water pump O-ring, and thoroughly clean the mating surfaces.
To install:
Install a new O-ring gasket in the water pump O-ring groove. Hold
the O-ring in place with a few small dabs of suitable silicone sealant.
WARNING
Before proceeding, make sure the O-ring gasket is properly seated
in the water pump groove before tightening the screws. A improperly
installed O-ring could cause a coolant leak.
Position the water pump to the block and install the retainers.
Tighten the retainers to 9 ft. lbs. (12 Nm). Use a pressure tester to
pressurize the cooling system to 15 psi and check the water pump shaft
seal and O-ring for leaks.
Rotate the pump by hand to check for freedom of movement.
Install the inner timing belt cover, timing belt and tensioner.
Install the right engine mount bracket and engine mount.
Refill the cooling system with the proper type and amount of coolant.
Install the power steering pump and accessory drive belts.
Connect the negative battery cable.
Use a DRB or equivalent scan tool to perform the camshaft and crankshaft timing relearn procedure, as follows:
Connect the scan tool to the Data Link Connector (located under the instrument panel, near the steering column).
Turn the ignition switch
ON
, and access the miscellaneous screen.
Select the re-learn cam/crank option, then follow the instructions on the scan tool screen.
Thanks for using FixYa - a
Very Helpful rating is appreciated for answering your FREE question.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
