20 Most Recent AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA Questions & Answers
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
AEG 7.59 cu. ft.... | Answered on May 04, 2009
good place to start is the starting device for the compressor.slip the cover off the compressor electrics on lhs of compressor usually and you may find the relay burnt out.tyhis is the mostly area but if elsewhere, look at the defrost element and check wiring loom
AEG 7.59 cu. ft.... | Answered on Mar 28, 2008
Obviously a dangerous short in the wiring. The CB is protecting you from a dangerous shock. My advice is get a repairman.
AEG Freezers | Answered on Jun 26, 2019
Possible free manual. Please let us know using the Comment menu if it is the manual you need. Thank you.
https://www.manualslib.com/manual/611434/Aeg-A92860gnx1.html?page=15
AEG A92860GNX1 User Manual Page 15
AEG Freezers | Answered on Jul 12, 2018
Check with your users manual offers any advice or follow this link
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
AEG Freezers | Answered on Dec 31, 2017
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
AEG Freezers | Answered on Jan 06, 2015
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Thermostat needs to be set
AEG Freezers | Answered on Jun 22, 2014
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
AEG Freezers | Answered on Jan 25, 2014
Check the refrigerant levels
AEG Freezers | Answered on Dec 21, 2013
AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA Logo
Popular Tags
8 questions posted
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
View Most Popular
AEG Freezers
  • AEG Freezers
Most Popular Question
upright freezer not cooling adequately
  • Freezers
