20 Most Recent
Pioneer VSX-516-K Questions & Answers
How can i reset pioneer vsx-516?
switch reciever into sstandby
2.while holding down the TONE button press and hols sown the standby/on button for about 3 seconds
3.when you see RESET? in the display press ENTER OK? shows in display
4.Press SETUP to confirm ok appears in display to confirm its been reset
3/5/2019 3:24:12 PM •
Pioneer...
Answered
on Mar 05, 2019
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
9/27/2011 4:58:17 PM •
Pioneer...
Answered
on Sep 27, 2011
My amp says overload and switches off only when i
This may happen for two reasons:
1. Bad air ventilation. Clean any ventilation holes all over the case and if possible open the cover and clean the dust using a brush and a vacuum or air under pressure. Take care not to make any damage at the wires, connectors e.t.c. with the brush.
2. Too many, or too low impedance speakers at each channel. In this case I have to know what speakers do you use in order to clarify if the speakers' resistance is too low for the amplifier and create this problem.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
3/3/2011 12:46:39 PM •
Pioneer...
Answered
on Mar 03, 2011
I want to program the aux thing on my comcast
There should be a "cheat sheet" on the inside of the battery compartment on the comcast remote, if not, simply contact a Comcast customer service tech and they should be able to walk you through programming your device. Most of the time there is a universal code (9,9,0,0) or something similar. Your best bet is to contact your cable operator.
12/11/2009 2:59:08 AM •
Pioneer...
Answered
on Dec 11, 2009
Audio Tape not recording
There is a bad IC in the preamp stage of this amp and will require a signal tracer to troubleshoot to see where the signal is lost. Good Luck
4/3/2007 7:11:12 PM •
Pioneer...
Answered
on Apr 03, 2007
TV/SAT Video channel went out - Pioneer VSX516
Double check the video connection cable directly out of the SAT reciver and the video cable out from the Pioneer reciver, as there maybe an intermittant connection in them. If you replace them or sub them for known good ones, and you still have this probem, there is a switching IC inside the pioneer that has to be replaced.
1/7/2007 12:54:06 AM •
Pioneer...
Answered
on Jan 07, 2007
Overloading
What speakers are you using? Are they seperate from the TV set? How is the audio attached to the TV set. What inputs I mean are you using for the speakers and the sound for the TV set?
12/10/2006 7:42:41 AM •
Pioneer...
Answered
on Dec 10, 2006
