20 Most Recent Muratec - MFX-1300 Copier Questions & Answers
0answers
0answers
Please call service
The most likely cause is either the fusing unit located in the right side door (orange in color) or a main motor lock. To determine what the trouble is, you need to enter the maintenance mode. On the control panel, press the "program * 6 keys in order. Press the right arrow key until service mode is displayed and press enter. If the display says heater error you have a bad fusing unit. If it says Rx motor, then the main motor is locking up. Check the drum and toner cartridge for motor lock problems.
8/4/2012 2:38:23 AM • Muratec -... • Answered on Aug 04, 2012
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
11/4/2011 7:32:10 AM • Muratec -... • Answered on Nov 04, 2011
Muartec 1300 error message .....Please call
Hi this is a standard message when the machine needs to be seriviced or parts need to be replaced because they have reached there life it is best to have a certified engineer service the machine for you
2/15/2011 5:31:40 AM • Muratec -... • Answered on Feb 15, 2011
We have been given an
Hi yes it may be caued by the charge roller arching or damaged replace the charge roller also check the transfer seperation unit for arching
the above will fix this issue
2/14/2011 1:37:55 AM • Muratec -... • Answered on Feb 14, 2011
My copier say open side cover and remove paper
Because it "thinks " there is a piece of paper jammed.
Open the machine make sure there is no jam, take out the paper cassette and check or change the paper for fresh paper...put the cassette back in and try to make a copy again. As a last resort try making a copy with a piece of paper thro the "by-pass" tray and see what happens.
11/16/2010 3:42:27 PM • Muratec -... • Answered on Nov 16, 2010
CHANGED TONER NOW A BLACK SMUDGE DOWN SIDE OF
There is a Black plastic cover that you close down on top off the toner cartridge....open that up and on the underside of that plastic cover you will see a row of small glass eyes...give them a wipe with a cloth or your finger as you may have gotten toner or dirt on the eyes.
11/5/2010 12:31:40 PM • Muratec -... • Answered on Nov 05, 2010
HOW TO I CHANGE CONFIRMATION REPORT
Instructions are on page 3.21 of the operators manual.
To switch the Report ON/OFF do the following....
Press PROG, C,1, 0, 3, ENTER.
pRESS to toggle setting On or Off...Press ENTER to save the setting.
11/2/2010 8:28:23 PM • Muratec -... • Answered on Nov 02, 2010
I cannot connect my MFX 1300 printer to my home
Yes...the MFX-1300 was only a copier/fax machine when originally sold, so there was no facility to connect to a P.C.
To connect to a PC there was an Optional Printer Control PCB available.
11/2/2010 5:26:03 PM • Muratec -... • Answered on Nov 02, 2010
When copying a document the copy comes out all
do you have the users manual??? if not get one at this address
http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp then try printing out a list or report of some kind...see if its still all black. If pages printed from memory are ok does the lamp undert the glass come on when you make a copy.???
10/8/2010 8:21:25 PM • Muratec -... • Answered on Oct 08, 2010
Just installed a new drum. and still get the
The new cartridge came with some paper work and you have to reset the life counter. I should be under the user funcation. Or you may have to have the cover open and turn it On. and follow the instructions
9/15/2010 3:04:34 AM • Muratec -... • Answered on Sep 15, 2010
We replaced new drum and
The drum should only be replaced when the display says "REPLACE DRUM" ...NOT when the display says "Replace Drum Soon"
...try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT
9/5/2010 2:16:44 AM • Muratec -... • Answered on Sep 05, 2010
What does please call service mean? alarm light
You most likely have a problem with the fusing unit....this will have to be repaired/replaced befor the error code will go away.
8/22/2010 2:29:30 AM • Muratec -... • Answered on Aug 22, 2010
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
6/29/2010 3:44:43 PM • Muratec -... • Answered on Jun 29, 2010
How do you make two-sided copies?
Afraid this is a "Simplex" machine. To make duplex copies you will have to put paper back in cassette to copy onto second side, and then turn original over on glass or into doc feeder.
5/28/2010 3:32:31 AM • Muratec -... • Answered on May 28, 2010
In need a part number for mfx 1300 control panel
I checked with the muratec web site and parts manuals don't seem to be available. You might consider upgrading to a new fax machine.
9/17/2009 11:51:33 AM • Muratec -... • Answered on Sep 17, 2009
Popular Tags
31 questions posted
Top Muratec Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Muratec Office Equipment & Supplies
Most Popular Question
cannot connect mfx 1300 printer home
  • Office Equipment & Supplies
