20 Most Recent Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive Questions & Answers
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
Xerox Workcentre... | Answered on May 18, 2019
yellow color missing of my xerox wc 7435 printer
Xerox Workcentre... | Answered on Mar 26, 2019
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
Xerox Workcentre... | Answered on May 18, 2018
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Xerox Workcentre... | Answered on Nov 28, 2016
Check around the fused assembly. Is it a new one, or is it one you put to one side as as a spare? If you have a service contract with Xerox you should be able to order a new one. I don't remember all they error codes but the 10 codes usually refer to the fuser unit.
Good luck.
Xerox Workcentre... | Answered on Aug 22, 2016
Did you restarted your xerox machine? Restart once and trying xerox again
Xerox Workcentre... | Answered on Sep 16, 2015
Hi
This is showing as a memory failure, either check your memory is correctly fitted and not loose, or if it is not then you might have to replace the memory. hope this helps
Xerox Workcentre... | Answered on Nov 25, 2014
Hi Arthur
Look at the cable that would connect to the hard drive.
The Data side is either SCSI, or ATA or SATA.
Look these up on Google and see what matches.
All modern Hard Drives are 3.5" for desktop computers or 2.5" for laptops. Visit a site such as OWC (Other World Computing) to purchase a drive.
Only Xerox would have the OS unless you know where there is an old copy.
Check out
https://www.google.com.au/?gws_rd=ssl#q=xerox+7435+specs
Xerox Workcentre... | Answered on Sep 10, 2014
This fault is coming on my copier 5755 what is the solution
Xerox Computers... | Answered on Jan 21, 2020
Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive Logo
29 questions posted
Top Xerox Computers & Internet Experts
Michael Thomas
Michael Thomas
JMJr
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Computers & Internet
Most Popular Question
download nvm tool xerox wc 7435
  • Computers & Internet
