20 Most Recent Toshiba HDD2J54 MK3259GSXP Hard Drive HDD2J54 Questions & Answers
2answers
How can I open a locked hard drive ?
It is locked whith password ?
9/20/2021 12:58:47 PM • Toshiba HDD2J54... • Answered on Sep 20, 2021
0answers
Electronic
Warranty 1 year (from date of purchase)http://storage.toshiba.com/storagesolutions/pc-notebook/mkxx59gsm-series
11/6/2013 12:32:18 PM • Toshiba Mk... • Answered on Nov 06, 2013
Mk 2559 GSX
I have wipro laptop with thoshiba hdd.when i try to install windows it shows no hdd deteted.please help
6/29/2013 5:43:17 AM • Toshiba Mk... • Answered on Jun 29, 2013
MK3252GSX wont take windows
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 hope this helpshttp://windows.microsoft.com/en-AU/windows7/products/system-requirements
2/18/2012 8:06:46 AM • Toshiba Mk... • Answered on Feb 18, 2012
2answers
Toshiba hard disk is very slow and do not accept the data, normally the speed of moving data by Kb/s. What is this problem? What can I do?
Switch the SATA Data Cable to Fix HDD Slow. The other quick solution to fix a slow hard drive, especially for the hard drive that fails in a fast file transfer speed, is to switch the SATA data cable from the first to the last SATA port. Sometimes, it's a problem of a dusty or loose SATA cable that slows down your HDD.
9/20/2021 5:39:37 PM • Toshiba... • Answered on Sep 20, 2021
2answers
Undefined Toshiba laptop pro C50 battery not charging showing Error 255.
From our Computer Guru and Expert Larry. Moved down here to aid searching this issue. laptop pro C50 The battery is bad, no battery this old lasts to year 2021 ever both batteries are the big one and the tiny coin cell RTC is dead. remove huge battery run on AC power only, (until PC is ok 100% later) 2013 made PC? the manual states this lame PC has a RTC that is rechargeable. so step one per manual is charge it over night wall AC plugged in and turned on PC. that is first but 8 years old many are not bad. RTC battery (shows lithium ION rechargeable in the book) page 108 tells you that the BIOS settings will be all wrong and more. it tells you to correct that after a good RTC battery is installed, or any one ran DEAD (discharged0 https://www.manualslib.com/manual/551765... the huge battery that old is no good. for fact. and both I bet are DOA. ..
9/20/2021 2:30:36 PM • Toshiba... • Answered on Sep 20, 2021
4answers
How do I unlock my
HI MARTYN,
Toshiba allow cheapo makes to use their brand name sometimes.
So if the player is not a genuine Toshiba then there is likely to be a remote hack on the net some where.
If it is a genuine Toshiba then there wont be a remote hack and you will need somebody like DVD Chips to send you a £20 remote that will hack it.
However - many Toshiba machines will not play NTSC discs at all when first set up.
Check out the Video setup menu and you will see a PAL/NTSC/AUTO option.
Tosh's I've seen are preset to PAL but unlike other players the Tosh will spit out any NTSC discs you try to play- set it to AUTO
Check that setting first just in case that is the only thing stopping it
Here's a Tosh hack to try
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
If the hack does work make sure the PAL/NTSC setting is on AUTO because R1 disc might still not play
9/19/2021 4:22:18 PM • Toshiba... • Answered on Sep 19, 2021
3answers
Need charger for toshiba PA3299u
7/28/2021 2:54:22 PM • Toshiba... • Answered on Jul 28, 2021
2answers
Where do I find the BIOS jumper pin/pad on a Toshiba Satellite C660D? I looked everywhere on the motherboard, but couldn't find it.
Short the two pins for 5 seconds with screw driver and restart the laptop, before doing this remove the battery and adapter
6/26/2021 1:56:38 PM • Toshiba... • Answered on Jun 26, 2021
Toshiba HDD2J54 MK3259GSXP Hard Drive HDD2J54 Logo
Popular Tags
5 questions posted
Top Toshiba Computers & Internet Experts
Ekse
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Mk Toshiba
  • Mk Toshiba
Most Popular Question
open locked hard drive
  • Computers & Internet
