20 Most Recent Toshiba 500GB STORE ALU2 PORTABLE USB2.0 EXTERNAL HDD SILVER Questions & Answers
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Toshiba 500GB... | Answered on Jan 13, 2014
Download a copy of EASEUS Partition Master Home Edition from the link below. It will convert the drive's file system for you. It's very easy to use and it's FREE.
http://majorgeeks.com/EASEUS_Partition_Master_Home_Edition_d5967.html
Toshiba 500GB... | Answered on Jun 26, 2012
I'm sorry, but this is not within my area of expertise.
Computers &... | Answered 14 hours ago
Effective Step by Step Process to Resolve Toshiba Scan File Storage Error:
  1. Navigate to Domain Controller Security Policy using Administrative Tools.
  2. Next, you need to choose Security Settings and thus click on Local Policies.
  3. Open Security Option Folder and thus check its details pane.
https://www.toshibasupport365.com/blog/how-to-resolve-toshiba-scan-file-storage-error/
Toshiba... | Answered on Mar 26, 2020
https://www.google.com/search?sxsrf=ALeKk02XxggLjAoW0iQXpCazGnOQHkSgiw%3A1585136631388&source=hp&ei=90N7XpDiFJKZlwS9goTQDw&q=How+To+Fix+Toshiba+laptop+error+no+bootable+device%3F&oq=How+To+Fix+Toshiba+laptop+error+no+bootable+device%3F&gs_l=psy-ab.3..33i22i29i30l2.1347.1347..4154...0.0..0.400.400.4-1......0....2j1..gws-wiz.PucmsUWs09E&ved=0ahUKEwjQudOOxrXoAhWSzIUKHT0BAfoQ4dUDCAU&uact=5#kpvalbx=_5kd7XrejM6KdlwSBoqGwBg39
When you see "No bootable device" in Toshiba, one of the possible reasons is your computer doesn't have the properly boot order, so your system couldn't find the proper boot device when starting. To fix the problem, you should set the boot order correctly.
https://www.drivereasy.com/knowledge/fixed-toshiba-no-bootable-device/
Toshiba... | Answered on Mar 25, 2020
On machines with the F key numbers on the bottom edge of the keys and in Gray: Power up the laptop. When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu. Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
https://support.dynabook.com/support/viewContentDetail?contentId=4010364
Toshiba... | Answered on Mar 20, 2020
Check on toshiba web site if there is update available for your model
Toshiba... | Answered on Mar 18, 2020
The following page offers information about a Toshiba recovery disk as well as alternatives. It does not refer to the Windows 10 OS, however. You would do well to check the Toshiba site for information about recovering your particular model and OS. A user guide should be available there. https://neosmart.net/wiki/toshiba-recovery-disk/
Toshiba... | Answered on Mar 17, 2020
The HDMI connector at your laptop is output. The HDMI connector at the DVD player is an output also. So it's out of the question to connect two outputs, you may want to use the HDMI output from the dvd player to be connected at a tv or screen with HDMI input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Toshiba... | Answered on Mar 04, 2020
SORRY NEVER HEARD OF THE GARMAN LANGUAGE HERE
Toshiba... | Answered on Feb 28, 2020
Uninstall the full game, check for any updates on your system, reboot and re-install the game.
Toshiba... | Answered on Feb 21, 2020
https://community.spiceworks.com/topic/1332654-does-anyone-have-images-of-the-toshiba-encore-2-wt8b-motherboard
Toshiba... | Answered on Feb 20, 2020
There's a bunch of videos on youtube. Here's one: https://www.youtube.com/watch?v=4y4yrygB9vc
Toshiba... | Answered on Feb 18, 2020
you need to put ur email in instead of phone number
Toshiba... | Answered on Jan 17, 2020
you are here because Toshiba's online help is gone. sure.
they tell you there to go to tomshardware and as there.
no PC stated at all model name and numbers..
what if kids set the password, playing with it.
remove the battery from the PC, big one
no AC pack.
push power button for 3 times for 10 seconds each.
wait,5min. hands off PC.
now put the AC pack back.
if the PW is still set, then next replace the coin cell battery inside.
on some Toshiba (none stated) that battery is a rechargeable and if bad, very hard to fix.
let the PC run on AC power only for 24hours in the hope that odd duck battery deep inside recharges, leave the big battery out for all tests, (until PC runs ok again on AC power)
never post about a PC unless, the full model # and name is told
example 1(random)
Toshiba Satellite L455d-s5976
Toshiba... | Answered on Jan 11, 2020
Sounds like your hard disk drive has died.
Fit a new SSD (solid state drive)
Did you make a boot disk / thumb drive like Toshiba recommends?
After you fit the new SSD run the boot disk.
No boot disk you will an O.S. to load onto you computer.
To run the boot disk you have to get into setup, press F2 when the computer starts.
Look for the boot disk options, if you are using Thumb Drive switch the boot option to USB.
If you are using a CD switch the boot option to CD.
Close the setup and reboot...
The boot disk will set up the Operating System with the usual questions.
Hope this helps
Geoff
Toshiba... | Answered on Jan 10, 2020
Toshiba 500GB STORE ALU2 PORTABLE USB2.0 EXTERNAL HDD SILVER Logo
4 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
laptop cannot detect hard drive no
  • Computers & Internet
