20 Most Recent Microtech Xpressscsi - Usb To Scsi Hd50 Converter / Adapter Cable / Jaz Orb Questions & Answers
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Microtech... | Answered on Jan 08, 2009
You have to check a sensor that hold a ********* cover under the feed table. I just closed that cover tightly
Computers &... | Answered 1 hour ago
you forgot to ask a question....
Computers &... | Answered 5 hours ago
new batteries, ..............................
I this video you will show how we can connect our Echo dot device to Alexa. It is the complete way to use of Echo dot to Alexa, use of Wi-Fi connection and Alexa skills.
Computers &... | Answered 10 hours ago
I would recommend downloading and installing VLC Media Player.
From Wikipedia http://en.wikipedia.org/wiki/VLC_media_player>
"VLC is a portable multimedia player, encoder, and streamer supporting many audio and video codecs and file formats as well as DVDs, VCDs, and various streaming protocols."
It's an excellent player, and can play almost any video file you have.
To download go to http://www.videolan.org/vlc/ and follow the instructions there.
Computers &... | Answered 13 hours ago
Computers use video files such as AVI, WMV, MPG etc.
DVD players use VOB video files, and will not recognise the computer video files.
Unfortunately, Windows Moive Maker cannot create VOB files - you will need another piece of software to convert the WMV file Windows Movie Maker creates to a VOB.
A lot of disc burning programs (e.g. Nero) include video converters. See if you've already got one on you computer.
If not, try Googling 'WMV to VOB'. There's quite a few free ones out there.
Hope this helps,
Matt
never do that, take to the maker first , doing updates wrong
will render it dead, even bricked.
talk to them and we are NOT them,
you posted to computers but it IS a sewing machine only.
ask them never on GP forums, or get told wrong.
ask them,
https://babylock.com/accessories/sewing/esante
Computers &... | Answered Yesterday
Video players in WIndows use shared system codecs.
So you must download codec pack like K-lite codec pack
Can you open them with another player eg The KMPlayer or VLC Player or even Windows player?
You may possibly need a set of codecs
Most complete set here, just download and install
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
You can download the codec you needed at: http://www.codecguide.com/
Probably you need K-Lite Codec Pack or K-Lite Mega Codec Pack.
Instead of using GOM which is an obsolete piece of **** why aren't you using a top of the line media player that has all the codecs already in? One like VLC http://www.videolan.org/
If you just want to put the video on a disc that will be played on a computer, you can simply copy the video file onto a disc as data. Windows has basic disc burning capability built in, but other applications give you more features. I use CDBurnerXP, which is free. Another free burner is InfraRecorder. Also, many computers come with versions of programs like Nero or Roxio preloaded. With one of these programs, you pick the "create a data disc" option, drag the video file into the appropriate window, tell the program to burn the disc, and you're done. Again, this would only play on a computer using a player like Windows Media Player, WinAmp or VLC.
If you are looking to make a DVD that would play on a regular DVD player, life is a little tougher. This is especially true if you want to add any features to the DVD like menus. You need a DVD authoring application for this, and the really easy-to-use ones are commercial versions that aren't cheap. There is a good, free program called DVDStyler that I use. It's a bit tough at first because the documentation is weak, but there are several YouTube videos and other sites that can help. The program lets you make your own menus, add background pictures and music, converts the video files to the format needed to make a DVD, and allows you to preview the disc before you actually burn it. The result, though, is a DVD that works like the ones you buy at the store.
Hope this helps get you started. Thanks for using Fixya!
Try this:
Get the Nero 9 application
Install it on your computer
Create a Video Disk
And browse the folder of the VOB files Add it to burn the disk
Select Burn to burn the DVD ....
You may also try to put in a blank dvd and copy all the files on the DVD drive
Select burn these files on the disk
This should work
Regards Soumajit
can not say do not know what it is on .
you are not subscribed you are a user. just leave if you dont like it and dont come back
Ok, well it could be the following
First off you should, Turn off your antivirus (just for testing) disable or uninstall Microsoft Virtual PC, it causes issues, and lastly disconnect IPV6.
90% of places and routers, and device cant support it yet. To see if its on, in windows,
click start, in the text box type CMD and hit enter
A black command prompt will show up
type
ipconfig /all
Scroll back up and if you see numbers other than Os in IpV6 its connected, you need to disconnect that.
TO do it that
click on your wifi signal in the bottom right of windows, go to open network and sharing access.
On the left, choose change adapter settings.
Per your connection type (wired or wireless) right click on it on it and go to properties.
under the setting Internet Protocol Version 6 (TCP/IPv6) uncheck the box if its checked.
hit OK.
Do this for all listed.
Restart windows.
Still a no go try the following
1. Check to see if the router needs a firmware update? When was the last time you did that?
2. What are your security features on the router. Your not MAC filtering or anything like that are you.
3. The card for the new Dell, what type is it. NIC is what I am talking about, is it B/G/N type. Or G/N. Does your router support 802.11 G/N or just A/B
4. Are you doing this WiFi or hardwired, I assumed hardwired cause you call it Ethernet.
5. Reset the router with no settings or security at all. Save you current router configurations first (if any) and there should be a button somewhere that you use a Pen to push and reset. Hold for 10 to 20 secs or longer. Now its a empty box until Comcast updates it to a new modem. (must do this to power cycle the RCA modems)
6. What is your NIC card? With a new system its a Gigabit, does the Modem support it. It shouldn't matter but check the cable too. Gigabit cards have bit parity meaning the can switch the bit. If you are using a cable that is wired different on each end, and your modem needs it to be wired the same on both ends it will never work.
7. Are you using a router also.
So here is what you should do.
1. Update all Win7 OS divers and software.
2. Update your Router Firmware if you have one.
3. If possible update your modem (usually you cant).
4. Unplug the modem and router (if you have it)
5. Plug in the modem, then press the reset button in the back until it reboots again (it could have old settings stored in it from where it came from.)
6. Plug your router into the modem(if you have it)
7. What on you Dell is managing your NIC. Is it windows, or Intel or what. Turn off all management software that is managing your NIC. Use windows if you are not using already.
8. Plug in the cable, and do the following
Open your browser hit stop and type the following
192.168.0.1 does it get to a admin window
then use
192.168.1.1 doe it connect to a admin window
192.168.100.1 or 0
this should get you into your admin screen in the router.
use the user name admin and password admin
or leave the user name black and type admin,
if that does not work look to your documentation.
if you can get in reset the thing and clear all settings within reason, if you are not OK with this, don't do it
NEXT
Run Ping and Tracert
How to use the ping command
Windows 7, Vista or XP:
Click Start->Run and type cmd and press Enter. This will open a black DOS window. When open, type ping -t www.comcast.net and then press enter.
The output will look like this:
Pinging www.comcast.net with 32 bytes of data:
Reply from 204.127.195.15: bytes=32 time=75ms TTL=46
Let this run for about a minute or so and press Ctrl and C to stop it. In the output, look for how often a Request timed out message appears and also look to see that the time=XXms part of each reply is as low as possible - below 100ms under ideal circumstances.
Are you loosing packets is so then nothing is getting out.
Tracert
Run a traceroute
Sometimes it is helpful to run a trace if you are having difficulty with a specific destination or service.
Windows 7 & 8, Vista or XP:
Click Start->Run and type cmd and press Enter. This will open a black DOS window. When open, type tracert www.comcast.net and hit enter. When it is finished, you will see a "Trace complete" message.
Are you going to them, or not?
If not then the internal firewall in the router is stopping you and you need the ip Addy to the router to change this. Here is the guide to your router, read up
http://www.simplehelp.net/2006/07/15/cable-modem-troubleshooting-rca-dcm425/
Finally you will need drivers if the rest is not working for Windows 7 and your modem/gateway this is a driver for windows 7 and that router http://www.driverssoftwareupdates.com/d/dhg_535_2.html
other than that you have to contact Comcast, or get the info for the admin settings in the router.
Finally, are you using the USB type connection or RJ45 Cat 5 cable. If your using a USB then disregard the Patch cable thing.
Also if you have one connect with the USB (its a fire wire cable and being that you have a gigabit NIC in your computer it should connect with no issues.)
Computers &... | Answered 2 days ago
Posted PHONES to Computers?
Paired with either the Mitel MiVoice Business or the Mitel SX-200 IP Communications Platform (ICP), the 5540 IP Console supports up to nine line appearances, eight call hold positions
seems best is RTM, read the manual or call maker for support?
https://lmgtfy.com/?q=5540+ip+manual
Microtech Xpressscsi - Usb To Scsi Hd50 Converter / Adapter Cable / Jaz Orb Logo
1 questions posted
Top Microtech Computers & Internet Experts
William Miller
William Miller
RockTheHood
Are you a Microtech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microtech Computers & Internet
Most Popular Question
screen jtx v
  • Computers & Internet
