20 Most Recent Eiki LC-SB20 Projector Multimedia Projector Questions & Answers
Yes, anytime the picture becomes dim, or the color begins to fade it is time to replace the lamp.
Eiki LC-SB20... | Answered on Feb 01, 2017
this can only be solved with remote control or connect the AC cord while pressing the SELECT button on top.
this will cancel the control lock
Eiki LC-SB20... | Answered on Apr 17, 2014
Try to lower the output resolution of your laptop for external display to
800 x 600, which is the native resolution for your SB20
1.leaking polarised glass parts in the blue channel.
2. worst case a leaking lcd panel, impossible and very expensive to replace, you will need a complete optical block
no indicator lights,means that is no electric current is found in Mainboard , the mainboard or main power is defective
maybe the ballast is work well ,is ok.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Eiki LC-SB20... | Answered on Feb 10, 2014
turn your contrast down to only 50% and same with your brightness.
Eiki LC-SB20... | Answered on Feb 13, 2010
make sure the resolution matches the input.
Eiki LC-SB20... | Answered on Aug 19, 2009
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Eiki LC-SB20... | Answered on May 05, 2008
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Eiki LC-SB20... | Answered on Mar 27, 2008
Hi there
First try another cable from the PC to the Projector.
The VGA / RGB Cable used from your PC to the Projector has a couple of very thin copper wires on the inside and they easily get damaged.
If this doesn't help then you should try another PC.
If that works then you'll know that it is the PC's card that is faulty.
If it doesn't work you'll have to get the Mainboard repaired or replaced , because the inputs on the Projector lies within the Mainboard.
Must warn you that a Mainboard replacement is a bit on the expensive side.
Hello again gabzky, My apologies for getting back to you a bit late. I understand that you followed the manual but was not able to resolve your problem. There is something else you can try, hard reset the unit. At the back of your LC-SB20 Projector between DVI-I and Service port, above and to the left of the computer/component in is a small reset button. You may need to use a ballpen to depress the button. You have to press this with the power on. Cheers and keeping my fingers crossed for you.
Eiki LC-SB20... | Answered on Aug 07, 2007
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
Eiki Office... | Answered on Jun 11, 2019
The Blue LCD has been damaged or the lens is discoloured with excess heat from an old lamp.
Eiki Office... | Answered on Oct 07, 2018
Eiki LC-SB20 Projector Multimedia Projector Logo
Popular Tags
15 questions posted
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
everything works fine just going dark
  • Office Equipment & Supplies
