20 Most Recent Eiki LC-XG110 Multimedia Projector Questions & Answers
long cables should be of perfect quality with low electric capicitance.
otherise echoes will occure and shadows in picture.
Try a good quality IP- converter set i.e. from EXTRON
You used a shorter cable with better results, so don't look for a cause inside the projector. Picture quality stands with cables !!
There is a lot of cheap rubbish in the market.....
Eiki LC-XG110... | Answered on Apr 17, 2014
you have to press the red button twice !! on screen you should see POWER OFF ? after first press, press once again to confirm.
Check if key and remote lock are both off.
This is probably one of three causes: 1. The lamp has reached the end of its life. 2. The projector is overheating because of dust buildup/position/etc. 3. The projector has an actual problem with its internal components. The lamp on a projector is very special and most likely won't just blow out like a regular light bulb. When a projector lamp fails, it's more like it can't sustain a burn, but probably won't have a lot of trouble starting one. The projector will probably have an indicator or what have you to indicate end of lamp life. If your projector has an air filter, make sure it's clean. Make sure the projector has enough space around it for proper ventilation and that it's on a flat, smooth surface (no carpet). If you rule out lamp life and overheating, you'll probably want to leave the problem to the manufacturer or a professional electronics repair person.
Eiki LC-XG110... | Answered on Feb 21, 2010
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
Eiki LC-XG110... | Answered on Nov 18, 2009
Clean air flow filters
Eiki LC-XG110... | Answered on Jan 22, 2009
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
Eiki Office... | Answered on Jun 11, 2019
The Blue LCD has been damaged or the lens is discoloured with excess heat from an old lamp.
Eiki Office... | Answered on Oct 07, 2018
possibly max lamp usage hours have been exceeded
Eiki Office... | Answered on May 04, 2016
Please lets know the model
Eiki Office... | Answered on Mar 23, 2016
Eiki LC-XG110 Multimedia Projector Logo
8 questions posted
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
start up problem
  • Office Equipment & Supplies
