20 Most Recent Eiki LC-XE10 Projector Multimedia Projector Questions & Answers
a short circuit in one of the power lines on the mainboard is most of the time the reason for immediate shut down
check all smd capicitors
Eiki LC-XE10... | Answered on Apr 17, 2014
In the personalization menu you should be able to make that happen.
Eiki LC-XE10... | Answered on Jan 10, 2013
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
Eiki LC-XE10... | Answered on May 12, 2011
teh power supply of your projector has a problem power transistor and mosfet might gone wrong you need to replace it.open the cover of your projector and take out the power supply.the power supply board is where the power cord is connected.check the fuse capacitors and transistors use a multitester to check the parts.transistors must not have a revers reading good luck and thank you
Eiki LC-XE10... | Answered on Oct 31, 2010
HI
PLEASE CHECK KEY PAD IF NOT WORKING SOMEBODY LOCKED .TRY WITH REMOTE .IT SHUOLD WORKED
M.R.CORPORATION MUMBAI -DUBAI
Eiki LC-XE10... | Answered on Aug 28, 2010
Hi Connecting a laptop computer to an overhead projector is a relatively simple process. That said, it can be a disaster to work hard on a presentation, be it for a school or workplace environment, only to show up and find yourself unprepared. Take the time now to learn about the different ways your laptopmag-glass_10x10.gif can connect to an overhead projector, and how to accomplish this easy task, and you can enter your presentation with poise and confidence.
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Eiki LC-XE10... | Answered on Jul 31, 2010
may be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Eiki LC-XE10... | Answered on Nov 18, 2009
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
I just did it, I took the filter out and then I cleaned it. After that all I did was reset the lamp and filter times which were at 160 for me, and now it works just fine. if the bulb goes out then maybe its time for a new lamp =(
Eiki LC-XE10... | Answered on Mar 27, 2009
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
Eiki Office... | Answered on Jun 11, 2019
The Blue LCD has been damaged or the lens is discoloured with excess heat from an old lamp.
Eiki Office... | Answered on Oct 07, 2018
possibly max lamp usage hours have been exceeded
Eiki Office... | Answered on May 04, 2016
Please lets know the model
Eiki Office... | Answered on Mar 23, 2016
Eiki LC-XE10 Projector Multimedia Projector Logo
11 questions posted
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
make computer show screen projection
  • Office Equipment & Supplies
