20 Most Recent Eiki EIP-2500 Multimedia Projector Questions & Answers
broken lamp or bad rotation of the colourwheel, a common problem for this model.
Eiki EIP-2500... | Answered on Apr 17, 2014
The bearing of the colourwheel is locked. No rotation of colourwheel possible, then also no lamp ignition. Colourwheel has to be replaced.
when connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
the connector between mainboard and DMD board should be clean.
even the pressure contacts between DMD and its boars should be spotless clean. takes experience to disassemle !!
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
difficult to find online, try comparable model of SHARP XG-MB55X
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Eiki EIP-2500... | Answered on May 12, 2012
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Eiki EIP-2500... | Answered on Sep 20, 2010
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Eiki EIP-2500... | Answered on Feb 08, 2010
press menu, go to scr-adj, down to prj mode, press enter, select front, and press enter.
Eiki EIP-2500... | Answered on Nov 17, 2009
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
Eiki Office... | Answered on Jun 11, 2019
The Blue LCD has been damaged or the lens is discoloured with excess heat from an old lamp.
Eiki Office... | Answered on Oct 07, 2018
Eiki EIP-2500 Multimedia Projector Logo
Popular Tags
20 questions posted
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
need new remote control
  • Office Equipment & Supplies
