20 Most Recent Cyberguard SG300 (00852503000366) Firewall Questions & Answers
Hej kan ikke huske brugernavn og pasvord
Cyberguard SG300... | Answered on Aug 29, 2012
I NEED TO GET ON RUNESCAPE
Cyberguard SG300... | Answered on Jan 04, 2010
Hi
Thanks for using FixYa. These are the main causes due towhich drops tunnel out and need a power cycle to reconnect. Please make sure thatthe Cyber Guard SG appliance has a default gateway by configuring the Internetconnection on the Connect to Internet page or assigning a default gateway onthe IP Configuration page. Ensure that the tunnel settings for the Cyber GuardSG appliance and the remote party are configured correctly. Also ensure thatboth have IP Sec enabled and have Internet IP addresses. Check that the CA hassigned the certificates. The remote party has gone down. The remote party hasdisabled IP Sec. The remote party has disabled the tunnel. The tunnel on theCyber Guard SG appliance has been configured not to re key the tunnel. Theremote party is not re keying correctly with the Cyber Guard SG appliance. Forfurther reference see the link---
CyberGuard SG 300 User Manual
Please do accept the solution if the issue is resolved orelse revert for further assistance.
Thanks
Rylee
Cyberguard SG300... | Answered on Oct 06, 2009
I had a similar problem a while back when I bought a new cable modem. I didn't realise that my cable provider needed to have the serial number of my cable modem configured on their system.
I ended up calling them to ask them about the problem.
There is no way I could have solved it without calling them.
I think it is to do with stopping unauthorised users from connecting to the cable.
I remember they wanted my name, age and grandma's inside leg measurement before they would help me.
So if you have nothing to hide just give them a ring and make them help you. This is what you pay them for after all.
Cyberguard SG300... | Answered on Jul 14, 2009
ok, on the internet window, click on tools, then internet options, then go to the ADVANCED tab, and click on the reset buttons and hopefully this fixes ur issue and if it does dont forget to rate me as FIX YA
Cyberguard SG300... | Answered on Feb 03, 2009
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Cyberguard SG300... | Answered on Nov 11, 2008
The ISP provider changed our IP address when we reset the modem.(even though they swear it was a fixed IP) The mailguard delivery address is fixed so the redirected mail from mailgaurd no longer had a valid address for delivery.
You can fix this by correcting the mailguard delivery IP address (phone them in business hours) or by providing Mailguard with a name address instead of an IP address .
Simple but frustrating until you think of checking to see if the IP addresses of your server and mailguard match
Cyberguard SG300... | Answered on Jun 19, 2008
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Cyberguard SG300... | Answered on Jan 31, 2008
From the main configuration screen select Network Setup, and then click on the Connections Tab. In the tabline below that click on Aliases.
At this point you input the Alias IP address and the netmask and add it, selecting port 25. The firewall now knows that it is to forward all traffic on port 25 to the computer that has the IP address you put in.
You should be aware that doing the above opens a direct access point into your network! Port 25 is the port used for SMTP (Sendmail) and it is the most vulnerable and most hacked service on the Internet! You should seriously consider not doing this.
A better option would be to goto the DMZ tab and configure a DMZ net on your firewall - you will need to obtain a second routable IP address from your ISP to do this though. By creating the DMZ and then routing port 25 to a machine inside the DMZ you isolate the machine running SMTP from all of the other machines inside your protected network and so make a compromise much less likely.
All of the systems inside your protected network will still have demand access to the machine in our DMZ, but the machine in your DMZ would be unable to initialize access to the protected network, which is a much safer setup.
Cyberguard SG300... | Answered on Nov 15, 2007
Which Firewall?
Model and make please
Cyberguard SG300... | Answered on Oct 19, 2007
This means that it is detecting the Operating system of the queried host wrong and I would simply ignore the error or turn detection off entirely. While it determines the operating system of the queried host by looking in detail at the network characteristics of the HTTP reply received from the web site. The reported operating system may be different to the one you expected because of any number of reasons that make it unreliable. For example:
  • The site could be using a web proxy cache, such as Novell BorderManager FastCache, Inktomi Traffic Server or a server running the open source Squid software. In this situation we will be connecting to the reverse web proxy rather than the originating web server, so will detect the cache's O/S rather than the web server's. Some proxy caching systems add headers to web server responses, such as the standard "Via" header. If the "Via" or "X-Cache" headers are found we report that the site is proxied.
  • The site could have a server load balancing device (SLB) like Cisco Web NS, Resonate Central Dispatch or BIG/ip. Some of these SLBs handle the TCP connection themselves, so we detect the SLB's operating system. Others use TCP/IP packet level Network Address Translation techniques, where we detect the operating system of one of the back-end web servers.
  • The site could be using a TCP connection-level proxy firewall, such as provided in the TIS Gauntlet, BorderWare, Raptor, CyberGuard or IBM SecureWay firewalls, or some other kind of HTTP level proxy. In these cases we will receive data from the intermediate machine rather than the web server, so detect the intermediate machine's operating system.
  • They could load shares across multiple servers using different operating systems with round robin DNS. In such cases each query might detect a different operating system.
  • They could have just changed the default configuration of their TCP/IP stack, perhaps for performance reasons, or have an unusual LAN environment.
  • Or something new has just come out and you have an older firmware revision that doesn't recognize newer packet standards.
Cyberguard... | Answered on May 13, 2010
$19 here
https://www.repairtoolparts.com/dewalt-parts/dewalt-dcr015-type-2-parts-list
My guess though it that it is a CR2032 battery available from Walmart for $5. Look on the top of it.
Computers &... | Answered 4 hours ago
and we would care about this????
Computers &... | Answered 7 hours ago
formatted data can be recovered with data recovery software, recommended asoftech data recovery
http://www.asoftech.com/adr/
Computers &... | Answered Yesterday
Google might have something then and the company’s official website too may have a service manual.
QuickBooks Hosting also known as QuickBooks Cloud or and Hosted QuickBooks) refers to the installation of the QuickBooks Desktop versions on the network server hosted over the internet to enable or allow access to a via a web browser from any locations.
Computers &... | Answered 2 days ago
Cyberguard SG300 (00852503000366) Firewall Logo
15 questions posted
Top Cyberguard Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Cyberguard Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberguard Computers & Internet
Most Popular Question
cable modem connection keeps repeating
  • Computers & Internet
