20 Most Recent
Amana AMV5206AAS Microwave Oven Questions & Answers
Our microwave is making sounds like an electric
HI.Though this suggestion may be recommended by those .but just to make sure how does the motor moves or rotates.If you can open both side of the oven if the motor boosing has been busted. Motor is reponsible of rotating the turntable,it has boosing on it try to check if it is already losse.And try to check also if there are debris that clogged in as the motor rotates.any metal that clogged inside the ovcen.hope this suggestion helps.Thank you for choosing FIXYA.
My Amana model number AMV5206AA over the range
you have burnt out the magnatron,,,(if i spell that right) its the part that heats up the food if there is nothing inside the microwave to absorb the waves they bounce around and end up hitting the magnatron this ages it to the point were it burns out,,,its not a cheap part,,and its far to risky for you to try to fix it so to be safe call out the repair man,,,but its not going to be a cheap repair
Amana RCS10TS control panel inoperative (no display)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiUw7318_L-AhX-GTQIHUoVBacQFnoECBIQAQ&url=https%3A%2F%2Fwww.repairclinic.com%2FRepairHelp%2FHow-To-Fix-A-Microwave%2F71-199--%2FAmana-Commercial-Microwave-Microwave-Display-Not-Working&usg=AOvVaw1_3-brehj_-McaojgE7G2S
Amana 10D microwave fan stays on, doesn't shut off until unit is unplugged and re-plugged.
If the fan in your Amana 10D microwave stays on and doesn't shut off until the unit is unplugged and re-plugged, there could be an issue with the fan motor or the control board. Here are some things to try:
1. Check to make sure the vent is clear and unobstructed. If the vent is blocked, it can cause the fan to stay on.
2. Check the fan motor. The fan motor is responsible for turning the fan on and off. If it is faulty, it can cause the fan to stay on continuously.
3. Check the control board. The control board is responsible for controlling the functions of the microwave, including the fan. If it is faulty, it can cause the fan to stay on or not function properly.
If none of these solutions fix the issue, it is possible that there is a problem with the microwave itself. In this case, it is recommended to contact a professional appliance repair service for further assistance.
Where is the fuse in an amana rcs10ts microwave and how do i get to it?
The LV control (mains side) fuse is on the control board.
The HV (lethal side) fuse is housed inside a plastic shell, next to the HV capacitor.
For both, the outer shell (microwave oven's cover) needs removal.
BUT:
Mains must be off, preferably about 15 minutes to allow HV capacitor to discharge through it's internal drain resistor.
AND:
There will probably be one or more security tamper-proof screws on the cover, to prevent accidental injury through electrocution.
WHY:
Microwave ovens are the most lethal household appliances to open when untrained hands poke around.
SUGGEST:
Get an experienced tech to check it out.
What makes you believe it's a fuse?
