20 Most Recent Asko T761 Electric Dryer Questions & Answers
Dryer making loud noise
Could be a few causes, but the most common is the drum roller wheel or wheels may have a bad bearing.
11/6/2015 11:17:59 AM • Asko T761... • Answered on Nov 06, 2015
Replacing light bulb
Open the door, remove the cover and have a few buddies spin the dryer in a counter-clock wise when viewing from the back. Remember you have to grab the bulb and hold it while they spin the dryer.
4/3/2015 12:23:35 AM • Asko T761... • Answered on Apr 03, 2015
2answers
Asko Dryer #7305 and F5 code...
Hi, Based on the explaination in your post I guess the unit will operate without anything in the dryer, correct ? If that is the case if you remove the lower panel you will reveal a plastic cover over the blower housing. Located on the housing you will find the moisture sensor usually hidden under some black puddy. Remove the gum type puddy and there you will find the sensor held in place. Remove the sensor and clean it out best as you can. Re-install the moisture sensor and give it a test. If that fails to remedy the problem you may indeed require a new sensor. Let me know and I can provide you with a part number or you can visit "repairclinic.com" and enter your model number and a description of the part you need. Hope this was helpful to you. Let me know or rate my info accordingly. Thanks for visiting "fixya" today and good luck. macmarkus :)
11/3/2014 2:23:59 AM • Asko T761... • Answered on Nov 03, 2014
High limit thermostat
A year ago, I needed to replace a high limit thermostat, and I received ( for the money) both the high and the low!. I replaced the high therm., and a month later, the low one went out. I discovered these need to be replaced as a pair only. Be blessed.
6/27/2014 1:25:27 AM • Asko T761... • Answered on Jun 27, 2014
Why is Asko Dryer t760 program menu is frozen?
Try to press STOP button for 3 sec :)
6/2/2014 6:47:49 AM • Asko T761... • Answered on Jun 02, 2014
Amana ndg7200tw dryer belt replacement
Unplug it from power,Take the top off the dryer. They "pop" on and pull off. Take the front panel off from the inside, Clean all the lint out, remove the old belt by sliding it off the front if it is not broken, put the new belt on, Stretch it to motor pulley, put the belt tensioner pulley on it, reassemble.
2/17/2014 10:21:53 PM • Asko T761... • Answered on Feb 17, 2014
0answers
Handleiding
Be the first to answer 1/3/2014 3:35:17 AM • Asko T761... • Posted on Jan 03, 2014Be the first to answer
Can you tell me what year the t761 came out?
this came around 2000. The four first digits of the serial number says the manufactering year and week. Ex. 9914 = year 1999 week 14
10/15/2013 3:34:12 PM • Asko T761... • Answered on Oct 15, 2013
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
10/15/2013 12:54:42 AM • Asko T761... • Answered on Oct 15, 2013
manual
T761 Electric Dryer Manual
Asko DryersUploaded on Aug 26, 2013
0answers
Asko dryer belt
Be the first to answer 6/30/2013 3:02:07 AM • Asko T761... • Posted on Jun 30, 2013Be the first to answer
0answers
0answers
Asko t761 fuse
Be the first to answer 10/13/2012 10:45:46 PM • Asko T761... • Posted on Oct 13, 2012Be the first to answer
2answers
ASko dryer T761 goes bump bump bump when starting.
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
8/29/2012 9:04:30 PM • Asko T761... • Answered on Aug 29, 2012
5answers
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
7/24/2012 3:41:13 AM • Asko T761... • Answered on Jul 24, 2012
The dryer stopped in the middle of a load, the
It seems that the main board, the program controller unit is a suspect and to confirm you need to remove the customer control panel and check . Check the +5 to the processor, check the connectors and the power supply, check for leak in the storage electronic capacitors, check for faulty voltage to the control board.- check rectifier and regulators.If not the fault can be the processor which must be confirmed with a data check or oscillations of the crystal.
9/29/2011 3:56:18 AM • Asko T761... • Answered on Sep 29, 2011
Asko T761 Electric Dryer Logo
54 questions posted
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ekse
Are you an Asko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Asko Dryers
  • Asko Dryers
Most Popular Question
dryer making loud noise
  • Dryers
