20 Most Recent Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C Questions & Answers
Hard disk failure or the hard disk is gone
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 25, 2018
Yellow LASER is bad. Its located under the yellow drum you need to replace it. You must purchase the LASER parts as (4) units one for each color but you can replace the a single unit
Konica Minolta... | Answered on Mar 04, 2018
depends on the model some do not have any and some have two what are you trying to do
Konica Minolta... | Answered on May 14, 2017
replace the rollers and clutches and one ways
Konica Minolta... | Answered on Mar 12, 2017
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
I would first starts by removing the Imaging units that are locked with blue levers below toner cartridges one by one for each colour and use the cleaning tool that is provided on the door (metal rod with handle and a pad on the opposite). When you pull the Imaging unit all the way out, you will see inside a long strip of LED and next to it on left hand side about a 1-2 cm another strip of MICRO LED Array. This is essentially yor print head and it has to be spotless clean. Use the rod and padded end to clean each of the arrays. This will give better sharpness and clarity to your prints. Then put Imaging Unit back in machine and pull the blue stick from the Imaging Unit out-in-out-in. The next step is to do Stabilisation and Gradation adjustments. This can be done in Service Mode. This should improve your printing. If it doesn't then you have either worn Imaging units _or_ Transfer Belt _or_ incorrect settings on Fuser or Fuser being worn.
Konica Minolta... | Answered on Nov 13, 2016
ERROR CODE C-0900 AND ERROR CODE C-0950
Konica Minolta... | Answered on Sep 30, 2016
Your Fuser cooling fan is not working.
eror code c-0098 meaning ??????????????pls tell me the solution
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Konica Minolta... | Answered on Jul 08, 2015
I looked through the service manual for this and I see "tech rep mode" listed. I don't think you can access this from your digital screen, but look for it. Other than that it suggested opening the "front door" and closing it again with the power on to reset. Hope this helps. If you manage to access the Tech Rep mode, there is a button to press to reset the machine...
Konica Minolta... | Answered on Nov 07, 2013
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Konica Minolta... | Answered on Sep 30, 2013
Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C Logo
52 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
just bought second hand konica minolta
  • Office Equipment & Supplies
