20 Most Recent
Akai CF2791 27" TV Questions & Answers
Picture but no sound
if you get sound from dvd then you know the audio output circut is good in tv try other video inputs for sound composite component
The television is blocked for
OK you need to look in your manual, for Child Lock, or Parental Controls, this is what needs to be Un-set, reset to clear this, a code needs to be entered..
Tv will not turn on. I have unplugged it and tried
check your b+ first. if your tv has no 125 volts your tv will not turn on check your horizontal transistor located in the side of the flyback transformer unsolder the collector then try to power on your tv check your high voltage at the collector without the collector of the horizontal transistor.
Power supply not switching
replace the regulators,check for change value resistors at the power supply section or resistors near the regulator.check for shorted diode and leak capacitors..also check the horizontal output v transistor..
Want to use only the cable remote, can't find the code
I recently bought a used LCT2060 that had no remote. I figured my
comcast cable remote would work without a problem but it didn't. So 3
universal remotes later I found my solution...a
radio shack
universal gamer remote. It controls up to 5 components plus your
xbox360, playstation and pc. The price on sale was a mere 12.97, not bad
if you ask me. Hope this helped. The code that worked for the
Akai
was 11676. Take care...
