20 Most Recent Akai LCT2660 26 in. HD-Ready LCD Television Questions & Answers
Look online for the manual--follow instruntions
Akai LCT2660 26... • Answered on Mar 04, 2015
Your TV has a long board that is called the LCD inverter board. I think this board is dead.
This long LCD inverter board's only job is to provide the TV LCD screen panel to have a back-light to the LCD screen panel to produce a picture.
Try websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Good luck.
Akai LCT2660 26... • Answered on Apr 20, 2011
Do you still have this TV?What does it do?Not power on?Power on,and then off again?You shouldn't have to replace the whole board,unless either it is beyond repair,or you don't have one to start with.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Akai LCT2660 26... • Answered on Apr 19, 2011
Are you still having trouble?Please let me know.Thank You very much!
Tyler
Akai LCT2660 26... • Answered on Mar 14, 2011
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
It has a weak prower supply , replace the elctrolytic caps, and that should take care of your problem.
Akai LCT2660 26... • Answered on Oct 16, 2010
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Akai LCT2660 26... • Answered on Sep 12, 2010
As you do not give any model number the answer will be of a general nature.
If it has 3 different crt tubes inside then the fault is with the convergance board or setting. this is not a job for the general public and should be looked at by a competant service engineer.
Akai LCT2660 26... • Answered on Jun 07, 2010
Did you fix this yet?Please let me know.Thank You very much!
Tyler
Akai LCT2660 26... • Answered on Oct 07, 2009
Tyler
Tyler
Call 800-726-4405 - But the part may not be available - request an exchange through the manufacturer. By law the manufacturer must provide parts for 5 years.
Akai LCT2660 26... • Answered on Apr 24, 2009
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Akai LCT2660 26... • Answered on Feb 28, 2009
You can buy a HDMI cable at any local electronics store. Walmart, Radio Shack, Sears just about anywhere. You can also buy them online. Search HDMI.
Let me know if this helps and if I can be of further assistance. Please rate this solution. Lone99star Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Akai LCT2660 26... • Answered on Jan 25, 2009
check the fuse
Akai LCT2660 26... • Answered on Jan 21, 2009
I WILL NOT BY AKIA TVS no more thay **** cant get parts
Akai LCT2660 26... • Answered on Dec 19, 2008
that sounds like your LCD controller, since the LCD screen is so big, they will "split" the screen into 2 smaller screens, otherwise it would be so outrageously expensive to have one big massive lcd controller. Your lcd controller is most likely a two-in-one card though, meaning that there are 2 controllers on one board. You'll more than likely need a new controller card for your tv.
Akai LCT2660 26... • Answered on Dec 14, 2008
When you turn the TV on and the color is off, if you were to bring up the TV's onscreen menu, is it in color or is it black & white too?
This will help determine if the issue is video board related or if it is the input/output board.  Since the problem is sporatic, it could be a connection issue and service is likely required.
Akai LCT2660 26... • Answered on Dec 10, 2008
I bought mine off Ebay.Radio Shack has some,but they didn't have the ones I needed,and they are more expensive.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Akai LCT2660 26... • Answered on Nov 02, 2008
Akai LCT2660 26 in. HD-Ready LCD Television Logo
Popular Tags
40 questions posted
Top Akai Televison & Video Experts
matt martin
matt martin
Lee Hodgson
Lee Hodgson
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
thomson scenium 44rw65us red light
  • Televison & Video
