20 Most Recent Akai PDP-4247 Television Questions & Answers
Picture on Akai PDP4273M1 suddenly degraded
You could smash the TV and find that it will work better or call a local repairman. I know the exact problem with this TV, but only a technician should even open a TV. The guy I got the TV from totally butchered the inside of his Akai in a failed attempt to fix his TV himself. Instead, he created a fire hazard and is lucky he did not burn his house down.
3/2/2011 4:39:04 AM • Akai PDP-4247... • Answered on Mar 02, 2011
How do i hook up coaxial cable
Straight into the RF connector on the tv. If you have a converterbox, satellite or cable box,connect to the input, box first, and then from the out point from box into the RF connector of you TV. Hope this works!
11/29/2009 6:32:09 AM • Akai PDP-4247... • Answered on Nov 29, 2009
2answers
Black vertical line
The drive module for the screen, or the screen itself has to be replaced. Either being defective can cause your described fault condition. The service tech would find the defective board by swapping them with new ones.
These parts are expensive.
There is no supported component level service on the circuit boards. They use complex SMD technology, and it would be impossible to troubleshoot these boards as like was done in the older days in equipment that used standard type components.
One way to fix your set, is to find another defective set of the exact same model, and swap out the required parts from it. The problem here is that there is a good chance that the same parts are defective in the other set. In this case, you would still be left with the same problem and have spent good money to buy another defective set.
If it was possible to have your TV set built with standard type discrete components, the electronics would be many thousands of times their size, and the cost would be unaffordable.
Jerry G.
9/6/2009 1:02:08 AM • Akai PDP-4247... • Answered on Sep 06, 2009
Tv turns on clicks but never comes on just clicks
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
6/2/2009 3:25:12 PM • Akai PDP-4247... • Answered on Jun 02, 2009
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at [email protected]
Thank you!
Dave,
4/8/2009 8:37:14 PM • Akai PDP-4247... • Answered on Apr 08, 2009
Black screen on Zenith plasma tv's
Hello, My name is Dave and I can help you fix your Plasma TV. Give me a call. Feel free to give me a call @ 1-503-432-9904 or message me at [email protected]
Thank you!
Dave,
1/29/2009 5:59:19 AM • Akai PDP-4247... • Answered on Jan 29, 2009
Dave
Thank you!
Dave,
1/29/2009 5:31:39 AM • Akai PDP-4247... • Answered on Jan 29, 2009
How can i fix my audio on my tv AKAI ??
Your main board is defective
8/6/2021 11:33:43 PM • Akai Televison &... • Answered on Aug 06, 2021
Akai crt sumo 25 is lock please give me sevice code
try to look for this..
7/11/2021 3:58:22 PM • Akai Televison &... • Answered on Jul 11, 2021
2answers
Akai u40 had the wrong power supply 5v ac i think now no lights or pkwer
Could be time for a replacement power board, if they are still available.
4/16/2021 9:23:14 AM • Akai Televison &... • Answered on Apr 16, 2021
2answers
Just have a 43 inches Akai smart TV When watching then it can suddenly turns off ......need your help don't understand
It's either a faulty power board, or a faulty switch board or an overheating issue and the set is going into protection mode. You need a television engineer to diagnose and fix https://www.fixya.com/support/r29790007-repairing_own_television ..
2/23/2021 4:40:23 AM • Akai Televison &... • Answered on Feb 23, 2021
What is the code of Akai led tv how to connect re-300e+ remote to this tv
The applicable code(s) would be in the remote control, if it is compatible.
1/13/2021 1:50:42 AM • Akai Televison &... • Answered on Jan 13, 2021
How do I connect my akai plasma tv model pdp4225m to antenna?
Attach the antenna to the appropriate connector on the rear
12/12/2020 4:34:45 PM • Akai Televison &... • Answered on Dec 12, 2020
Where i get the EHT of Akai Tv
EHT or Extra High Tension is the power supplied to the final anode of the cathode ray tube. The EHT is traditionally generated by the line transformer from the flyback pulse of the line oscillator/amplifier. The generated high frequency high voltage current was from the outset rectified by a thermionic diode (eg. EY51, EY86) but by the late 1960s/early 1970s technology brought high voltage diodes and semiconductors rapidly replaced the old technology and the output from the line transformer then typically fed the anode via a semiconductor voltage doubler. The rectified EHT was originally smoothed by a high voltage oil-filled capacitor but that was soon deleted in favour of spraying the outside of the CRT with a metallic paint and grounding it. This became the high voltage smoothing capacitor with the glass of the CRT being the dielectric and the final anode the positive pole...
10/12/2020 1:20:02 AM • Akai Televison &... • Answered on Oct 12, 2020
Need replacement remote control 5.1 Akai HHT-006
is it working ,i want the code
9/27/2020 4:13:48 AM • Akai Televison &... • Answered on Sep 27, 2020
My Akai has lost a much watched channel overnight. I have tuned the channels, but still unable to recover. What else can I try?
Check if the channel is off-the-air due to an issue at the transmitter. After a severe storms, some local stations lost their transmitter because the tower fell. More often, the transmitter hardware can fail. One station repeater near me had an interesting period where it didn't get the incoming signal from the primary transmitter. Check that your antenna hasn't shifted to point away from the transmitter. Reposition the antenna, if needed. If you have an amplifier on your antenna, check if that has been damaged. If it has been damaged, replace it. My household found that the antenna/splitter became a filter for one VHF channel when damaged by a lightning strike. The check was to connect the antenna to one TV without the amplifier. The other common issue is interference. Has there been construction in your area that added a large building between you and the transmitter? I hope this helps. Cindy Wells
9/6/2020 5:17:00 PM • Akai Televison &... • Answered on Sep 06, 2020
Purchased a brand new Akai AK6520NF TV yesterday - today the tv turns off every 10mins. Any suggestions on what this might be or how to fix please & thanks
First try checking the "auto off" function. I am not familiar with Akai TVs so this advice is very basic. Use the 'Menu' button and find Settings, (It might also be listed as Set Up). Go into this section of the settings. There should be a feature listed as 'Time' or 'Timer'. Set this to Off. Your other option, if it is a brand new TV is to contact the store you bought it from and ask their advice.
7/3/2020 7:45:57 AM • Akai Televison &... • Answered on Jul 03, 2020
How do i fix my akai tv stuck in startup screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
5/5/2020 12:38:26 PM • Akai Televison &... • Answered on May 05, 2020
2answers
AKAI tv ct 2206 samurai flat 2400 Watts pmpo . Sir tv colour is ver low .plz help me sir
Kindly read the instrunctions on the photo below.
Thank you for using Fixya.
4/17/2020 11:16:19 AM • Akai Televison &... • Answered on Apr 17, 2020
Televison & Video Logo
13 questions posted
Top Akai Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
tv turns clicks but never comes just
  • Televison & Video
