20 Most Recent Hunter (25417) Ceiling Fan Questions & Answers
capacitor tis toast. Have done what you did once. Just remember if/when replacing it...
The capacitor leads are color coded but the motor leads may not be! Tag the motor leads with colored tape before disconnecting the old capacitor, if necessary. Been there too! Differ by brands whether they are color coded.
Hunter (25417)... | Answered on Feb 25, 2018
Probably the switch for the light assuming it's not the bulb.
Hunter (25417)... | Answered on Nov 15, 2017
Been There, there is a small remote box inside the case,, if you buy Harbor Breeze 3 speed fan switch with dimer light they come together,,, but Heck,,, it's $60.00 US !!!
I always look for the simplest answer first.
This MAY be the problem: you reinserted one or more of the batteries with the wrong orientation. Typically, they will connect in series to produce a higher voltage than a single battery by itself.
For example, an AA battery puts out about 1.5 Volts, and two AA's in series would produce about 3 Volts, with the positive of one battery connecting to the negative end of the other; the negative of the first and the positive of the second connect to the remote's terminals. The connection between the two batteries is usually in the battery holder in the remote, and the batteries will be physically oriented in opposite directions. For example:batts-g3g4rd04a0x5u31qpoveqzom-1-0.gif
Of course, something inside the remote may have broken instead, but double-check the battery connections first.
Hunter (25417)... | Answered on Nov 14, 2017
I put my ceeling fan up today but I have just noticed the motor is reslly hot ,,,, HELPPPPP
Hunter (25417)... | Answered on Sep 15, 2016
In a typical ceiling installation, the fan assembly is attached to a downrod which, in turn, is securely attached to a junction box in the ceiling.
Hunter (25417)... | Answered on Dec 13, 2015
mcdevito75 here, You can check with any store that carries Ceiling fans for replacement parts, and contact info, you can check online at Hunter fans.com hope this helps.
Hunter (25417)... | Answered on Nov 27, 2015
Lights are wired separately. Check the wires that come from the light fixture through a hole in the center of the fan and come out at the top with the rest of the wires. Check wiring diagram in manual. Good luck!
Hunter (25417)... | Answered on Jul 29, 2015
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Hunter (25417)... | Answered on Sep 23, 2014
There are bearing in the fan but they are sealed. You could take it down and clean it real well. The bearings are hard to get to and the fan is not that expensive to replace.
Hunter (25417)... | Answered on Aug 29, 2014
Hunter (25417) Ceiling Fan Logo
214 questions posted
Top Hunter Dryers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
ceiling fan light doesnt work part bad
  • Dryers
