20 Most Recent
Clarion (VRX765VD) Car DVD Player Questions & Answers
Have sound, no picture
see if the disc turns, if not, try adjust slightly clockwise the preset resistor located near the laser head, here, it's a critical adjustment,usually there's 2 preset one is coarse the other is fine to define its beam's length and fineness but also check from a mirror reflection at right angle if you have a beam emission from the laser. If you have a beam too short not to touch the disc surface then you have a no disc indicator. But if you have a revolving disc, have audio but no video, then you have simple test to do, after 5 minutes of operation try touch the top of all IC marked with the word 'video' with the back of your finger to feel for excessive heat, if one produces too much heat in excess of 75degcel then you may replace the PCB or time has come to buy a new set.
2/21/2012 2:33:35 PM •
Clarion...
Answered
on Feb 21, 2012
Clarion VRX925VD gives me an
Error 6.CD error message. Could not read data from disc because it is upside-down. it's mean the problem caused by the optical lens of your DVD..you can try to clean first the surface of the lens..You can clean the lens with rubbing alcohol or one of the lens
cleaner discs. If that doesn't work, I would guess the pickup is bad. At
which point you would be better off just buying a new CD mech. But, if I
remember correctly, most of Clarion's CD mech's are really expensive;
70-160$
It's up to you to decide if you want to replace it or not. Hopefully help
10/25/2010 11:07:23 AM •
Clarion...
Answered
on Oct 25, 2010
Need installation manual for clarion vrx765vd
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
8/19/2010 8:23:34 AM •
Clarion...
Answered
on Aug 19, 2010
How do i hook up the dvd player for a Clarion
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
grey fr right +
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
brown phone interrupt
grass green park brake connect this to earth if u want to watch dvd whilst driving
pls rate
8/16/2010 5:42:13 AM •
Clarion...
Answered
on Aug 16, 2010
Lost face plate
Try an Ebay search for a used one.
If not, your Main Dealer
9/1/2009 10:03:28 PM •
Clarion...
Answered
on Sep 01, 2009
UNLOCK CODE REGION FOR CLARION VRX765VD
these codes are hacked into by persons more savoy than me, I have gone to the blog sites where they exchange the info about "region hacks" as they call it, no hack exists yet for your paticuliar DVD player, check back in a few months for an update, will be glad to keep looking..
9/1/2009 10:02:37 PM •
Clarion...
Answered
on Sep 01, 2009
How To Bypass The Brake Switch To Watch Videos While Driving?
Clarify please-does the screen show "Audio Only" when a DVD is inserted? If so, this is because the parking brake lead is not set up to work. Normally, the green lead connects to the parking brake negative on the car. This means you don't get video unless the parking brake is set. To bypass this, you need to wire the green parking brake lead to one terminal on a toggle switch, then you run a wire from the radio ground lead to the other terminal. toggle the switch up and down and you should have video. You can get a pretty small toggle switch and mount it in a concealed place.
This is by no means advocating watching video while driving!!!!
12/4/2008 6:23:16 PM •
Clarion...
Answered
on Dec 04, 2008
Faceplate
I lost my faceplate for my radio I looked for it for 2 month and the way I found it was at ebay.com
they sell the remote too I payed $65.00 for them both .Good luck!
11/4/2008 8:04:41 PM •
Clarion...
Answered
on Nov 04, 2008
