20 Most Recent
Clarion DXZ665MP CD Player Questions & Answers
Reset my clarion car stereo
There will be a small reset button on the faceplate or behind it when the faceplate is removed. Press it with the tip of a ballpoint pen while the ignition (car) is turned on.
Press and hold it for about 5 seconds.
Need to know what all
To know all the functions of the buttons and also the detailed operating steps, you can download the complete instrcuction manual in PDF format by clicking this
link
The functions of the buttons are given on pages 5-8 of this manual.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
My clariondrb3675 car radio was
try checking all of your fuses first. i'm not sure if there is going to be a fuse in the wire harness or on the back of the radio also. it wouldn't hurt to check.
Error 3
plug of car battery for 5 minutes then reconnected again with switch of CD player .
Lost puller, how do i get unit out to attach
I'm guessing you mean the keys that slide between the radio and the dash, ask around to see if maybe one of your friends has an extra set you could borrow.... If thats not possible try using two butter knifes (one for each side) and usually that will move the locks out of the way so you can pull the stereo out.
Error 6 comes up every time i put a cd in
This error 6 means that the unit can not understand the cd format try a different cd
it can also be a bad or death laser lens and it can not read the
information from a good disc you can try first running a lens cleaner but if still same error unit needs to be service.
Not accepting cd's
what seems to have is an alignment problem in the mechanism or the optics are also damaged
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Stuck cd
You can take two butter knives and slip them into the CD player and grab the CD. You should be able to see it in there. Just use the knives like a set of tongs. I did this before worked well, I actually used tweezers to do it as well. Each should work well
