20 Most Recent
Akai DVM-9500 Multi-disc DVD Player Questions & Answers
Need Codes for Akai television using Stang F-2100 universal remote.
It is 2023, no one uses Universal Remotes these days!
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Codes are to the television maker, they don't change depending on the make of remote used. But as I said, no one buys universals, you buy a copy remote made for the make model you have.
Akai TV universal remote control codes (3, 4 and 5 digit)
eliztech.com
https://www.eliztech.com > remotes > codelists > akai-t...
Universal remote codes for Akai TV sets - 3 digit, 4 digit and 5 digit codes. ... Mixed Akai TV codes from nine brands of universal remote controls.
3, 4, & 5 Digit Akai TV Remote Codes with Programming Guide
smarttvremoteapp.com
https://smarttvremoteapp.com > akai-tv-remote-codes
Akai TV Remote Codes for DirecTV ; 11385, 11692, 11935, 12232 ; 10765, 10812, 10030, 10098 ; 10672, 11676, 11689, 11690.
Universal Remote Codes for... ·
Akai TV Remote Codes for Dish
I have a pdp4298ed1 akai TV with a digital antenna screwed into the ant in. How do I scan for digital channel's?
To scan for digital channels on your Akai PDP4298ED1 TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to select the "Setup" menu and press "OK".
- Use the arrow buttons to select the "Installation" option and press "OK".
- Select "Automatic Search" or "Auto Scan" and press "OK". The TV will begin scanning for digital channels.
- Once the scan is complete, the TV should display a list of channels that it has found. You can then use the arrow buttons to select a channel and press "OK" to tune to it.
If the auto scan feature does not work, you may need to try a manual scan instead. To do this, follow the same steps as above but instead of selecting "Automatic Search", choose "Manual Search" and enter the frequency of the channel you want to tune to. You can find the frequency information for your local channels by doing a quick online search or checking with your local TV provider.
Akai 65" led fhd sm tv shows logo then turns off by itself
The reason you're not finding any bad caps is that's not the issue. If it was the set wouldn't power up then shut down, faulty caps don't cause issues like this. One thing that would have helped is the model number but I have a good idea what's causing your issue. When the set is powered on it goes through the boot log sequence, this is stored in the EEPROM that's located on the main board, chances are if you take a can of freeze spray and freeze the IC the set will power up as this IC isn't used once the set has powered on but it would only work one time but it's a way to confirm if this is the issue. If you have advanced solder skills you can order an IC and replace it for under 20 bucks, but it's not something easy to do without the skills or equipment, the other option is replacing the main board, however that may run more than it's worth so buying a new TV may make more sense
