20 Most Recent Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White) Questions & Answers
Why does my fridge keeps beeping every 10 or so hours
Check to see if it is closed properly, sometimes something sticking close to the door will keep it cracked open far enough for the system to detect a problem, if that isn't the case, try this, I found a simmilar case here on Fixya, that looks like it was solved, http://www.fixya.com/support/t212511-beeping_constantly_in_middle_night also Whirpool has forums that are rather informative http://forums.whirlpool.net.au/archive/1369884 unfortunately I can't give You much more than that, sorry.
8/27/2014 6:04:36 AM • Fisher and... • Answered on Aug 27, 2014
2answers
Freezer & fridge not working
check you compressor relay. could be bad.fan motor might be dead If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/16/2012 3:26:49 PM • Fisher and... • Answered on Oct 16, 2012
I have a Fisher &
It sounds like your freezer is going into reverse cycle and therefore still running but defrosting. Sensors or control unit could be faulty.
1/31/2011 8:49:22 PM • Fisher and... • Answered on Jan 31, 2011
My problem is that the two vegetable drawers are
if theres condensation on the walls too, check the door seal,it could be letting in warm air from outside,also if there are slide vents on these drawers open them so you get air flow
2/15/2010 8:16:01 AM • Fisher and... • Answered on Feb 15, 2010
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
1/31/2010 5:17:35 AM • Fisher and... • Answered on Jan 31, 2010
Fisher and paykel fridge light keeps blinking
bulb needs changing or lose conection
12/23/2009 9:11:18 PM • Fisher and... • Answered on Dec 23, 2009
3answers
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
4/27/2009 12:31:56 AM • Fisher and... • Answered on Apr 27, 2009
My F&P E372B fridge freezer starts beeping with the doors properly closed.
It is an alarm state, either it thinks the door is open or the temperature is not within specs. check the door gaskets are sealing properly? Your best bet is to get a service visit.
1/23/2022 8:31:56 PM • Fisher and... • Answered on Jan 23, 2022
Fisher Paykel F/F N3958 overflow seems blocked in fridge causing pools of water
Edited question to correct spelling of 'Fisher', as they aren't German. ;>) Moved category from Washing Machines to Fisher Paykel Refrigerators. Videos on how to unblock the drain https://www.google.com/search?q=fisher+paykel+fridge+blocked+drain ..
10/17/2021 1:06:21 AM • Fisher and... • Answered on Oct 17, 2021
3answers
Fisher paykel French door fridge shows F20 error everylme the door is opened - it beeps
F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires together with a auto12v type connecter or solder it and use shrink tube. Switch the fridge back on and hay presto, you can fill your fridge to the max 3 times over with the money you just saved. It will happen again as the wiring loom they fit is well and not flexible. Use silicone insulated wire from J-car or similar and replace from the plug and reconnect inside the door where the wires don\'t bend. Hope this helps you.
10/8/2021 9:28:54 AM • Fisher and... • Answered on Oct 08, 2021
How do I fix a F2 Fault on my refrigerator - Fisher and Paykel Refrigerators
The F2 code on the active smart model relates to an EVAP SENSOR RESISTANCE FAULT which means the resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms). In the first instance - Check sensor connection at the controller but if that does not resolve the problem then the sensor would need replacing.
5/8/2021 2:06:42 PM • Fisher and... • Answered on May 08, 2021
20 beeps when i open my fisher and paykel fridge. I changed the spring on the door hinge and now it beeps when ever i open the door.
Turn the Fridge OFF at the power socket, wait 10 seconds and turn it back On. If still beeping, You will need a Service Technician to assist with this. See the site below for more help or to schedule a tech visit.
3/27/2020 2:44:40 AM • Fisher and... • Answered on Mar 27, 2020
2answers
My fridge freezer is leaking due to condensation at the top of the fridge.
Try blowing compressed air up the drain tube.
1/4/2020 7:44:11 AM • Fisher and... • Answered on Jan 04, 2020
2answers
How can I access the defrost heater on my fisher and paykel "active smart" fridge?
HEY!!!!! If your breaker is tripping it means you have a short circuit - a serious safety issue. Unless you are a qualified electrical tech, for safety reasons refer this one to a pro.
10/18/2019 10:02:57 AM • Fisher and... • Answered on Oct 18, 2019
Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White) Logo
Popular Tags
20 questions posted
Top Fisher and Paykel Refrigerators Experts
Dan Webster
Dan Webster
Gil Shultz
Jay Finke
Jay Finke
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Refrigerators
Most Popular Question
fridge 14 yrs old unplugged 2 yrs now
  • Refrigerators
