20 Most Recent Fisher and Paykel DS602 Dishwasher Questions & Answers
What is the flood switch on a dw60cdx1
We had an F1 error with our F&P dish draw,Isolated the power to machine, then I removed the drawer & cover from the flood sensor, Dried water with towel & used hairdryer. Power cycled the unit & has fixed the problem. Had used a different powder & believe that it created more foam that caused the machine to flood slightly
1/3/2017 9:57:41 PM • Fisher and... • Answered on Jan 03, 2017
2answers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
6/8/2016 3:46:10 AM • Fisher and... • Answered on Jun 08, 2016
2answers
Where is the reset button for the flood switch
There is none. You have to dry the base of the dishwasher housing where flood switch is located. Make sure the dishwasher is plugged off before you attempt any work on it. Take the drawer out and use towels and hair dryer to dry the base under the drawer. The cause of the leak needs to be determined. Perhaps broken lid seal or leaky hoses.
5/19/2014 10:44:20 AM • Fisher and... • Answered on May 19, 2014
0answers
Amp f1 reset
Be the first to answer 12/24/2013 7:45:08 AM • Fisher and... • Posted on Dec 24, 2013Be the first to answer
Need to replace door spring
Please check for tips from the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
8/8/2011 5:03:37 AM • Fisher and... • Answered on Aug 08, 2011
0answers
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
6/4/2010 2:54:54 AM • Fisher and... • Answered on Jun 04, 2010
Please tell me where to find float swich in fisher
is this dishwasher a dishdrawer unit or is it a freestanding unit. if it is a freestanding unit it has a pressure switch. if it is a dishdrawer it relies on how many amps it takes to turn pump. hope this helps. what is the problem with your unit? please reply 4 more help.
5/4/2010 11:13:51 PM • Fisher and... • Answered on May 04, 2010
Does anyone have the manual for fisher & Paykel DS
yes I do but how can I give it to you?? live chat?
5/2/2009 4:13:18 PM • Fisher and... • Answered on May 02, 2009
Fisher & Paykel DW60FC Series (Freestanding Dishwasher). Have fault F30 repeatedly, after rebooting mains power supply. Please help.
Question edited for a lot more clarity. Your 'Possess F&K DW60FC' does not exist! :>D Question moved from Televisions category. Rebooting is not the fix, it won't work until you fix the pumping out. Fisher and Paykel dishwasher error codes f30 The F30 error code signifies that the flood switch on your machine has been activated. This indicates a problem with water drainage. This could be a one-off issue, or it could be a symptom of something deeper. For example, if the drain hose is bent or blocked, it could cause dishwasher problems like flooding.
How to Fix F30 Error on Fisher and Paykel Dishwasher
https://unitappliances.com.au > how-to-fix-f30-error-on-... Search for: Fisher and Paykel dishwasher error codes f30
4/8/2023 4:48:45 AM • Fisher and... • Answered on Apr 08, 2023
Fisher Paykal DD60 dishwasher - strange issue - beeping when needs to drain
If your Fisher Paykel DD60 dishwasher is beeping when it needs to drain, it may be experiencing a drainage issue. Here are some steps you can try to diagnose and fix the problem:
  1. Check for Blockages: Make sure that there are no blockages in the drainage hose or filter. A blocked drainage hose or filter can prevent the dishwasher from draining properly, which can trigger the beeping sound. Remove any blockages that you find.
  2. Check the Drain Pump: The drain pump may be faulty, which can prevent the dishwasher from draining properly. Check the pump to ensure that it is functioning correctly. If the pump is not working, it may need to be replaced.
  3. Check the Drain Valve: The drain valve may be faulty, which can prevent the dishwasher from draining properly. Check the valve to ensure that it is functioning correctly. If the valve is not working, it may need to be replaced.
  4. Check the Control Board: The control board is the brain of the dishwasher and controls all the functions. If it is faulty, it can cause the dishwasher to not operate correctly. Try resetting the control board or replacing it if it is faulty.
  5. Check the Sensor: The sensor may be faulty, which can cause the dishwasher to beep when it needs to drain. Try cleaning the sensor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the dishwasher thoroughly and ensure that it is working correctly and safely.
3/9/2023 3:09:36 PM • Fisher and... • Answered on Mar 09, 2023
What error code is on Fisher and Paykel dishdrawer DD60DDFX9 flashing leds
About the F4 error code on the Fisher and Paykel DD60DDFX9 dishwasher: The F4 error code on your DD60DDFX9 dishwasher indicates a fault with the heating element or the temperature sensor. When the dishwasher encounters a heating fault, it is unable to heat the water to the correct temperature required for the wash and rinse cycles. This can result in poor cleaning performance and may also affect the dishwasher's ability to sanitize the dishes. To troubleshoot the F4 error code, you can try the following:
  1. Check the heating element: Use a multimeter to test the heating element for continuity. If the heating element is faulty, it will need to be replaced.
  2. Check the temperature sensor: Test the temperature sensor using a multimeter. The sensor should show a resistance value of between 10,000 and 12,000 ohms at room temperature. If the resistance value is outside of this range, the sensor may need to be replaced.
  3. Check the wiring and connections: Inspect the wiring and connections between the heating element and the control board. Make sure all connections are secure and free of damage or corrosion.
  4. Check the control board: If the heating element and temperature sensor are both working properly, the issue may be with the control board. A certified repair technician will need to diagnose and replace the control board if necessary.
2/26/2023 10:32:57 PM • Fisher and... • Answered on Feb 26, 2023
Dishwasher Fisher and Paykel DD24SCTW9 dishdrawer LCD display is out
If there is no light or display on the LCD and the buttons are not functioning on your washing machine, and you have verified that there is power to the motor controller module and the wash controller module, it is possible that the issue is with the LCD or the ribbon cable that connects the LCD to the control board. To narrow down the location of the fault, you can try the following steps:
  1. Check the ribbon cable: Inspect the ribbon cable for any visible damage or loose connections. You can also try gently wiggling the cable to see if this affects the display.
  2. Check the control board: The control board is responsible for controlling the various functions of the washing machine, including the LCD. If the control board is faulty, it can cause issues with the LCD.
  3. Check the LCD: The LCD itself may be faulty and not functioning properly.
If you are unable to diagnose and fix the problem on your own, it is recommended to have a mechanic or appliance repair technician take a look at the washing machine. They will have the necessary tools and expertise to properly diagnose and repair the issue.
1/11/2023 6:02:07 AM • Fisher and... • Answered on Jan 11, 2023
Dishwashers Logo
25 questions posted
Top Fisher and Paykel Dishwashers Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Dishwashers
Most Popular Question
reset button flood switch
  • Dishwashers
