20 Most Recent E-Machines W3105 PC Desktop Questions & Answers
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Hope this helps.
E-Machines W... | Answered on Jan 04, 2013
a notice via e-mail ? That is likely a scam/virus-redirect attack...with the 'submit' button being the attack. Your Anti-virus program may have automatically removed the malicious link for you so you would not have infected yourself.....
E-Machines W... | Answered on Sep 01, 2012
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
E-Machines W... | Answered on Aug 28, 2012
Your name Edit > My Problems > My Problems. Do you mean restarting PC? Or re-installing?
E-Machines W... | Answered on Aug 27, 2012
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if this is for a web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply
hope it helps
E-Machines W... | Answered on Jul 23, 2012
do you get any error message?
You will have to reinstall your Operating System only.
E-Machines W... | Answered on Jun 15, 2012
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
E-Machines W... | Answered on May 09, 2012
which antivirus u use...tell me
or start --all program accessories --system tools---then click security center.open it...then u click all enable
E-Machines W... | Answered on Feb 19, 2012
to boot a cd then you must have the bios set to allow it, or tap f12 immediately to intercept boot menu and choose cd. sounds like your drive has a few bad disk sectors.
E-Machines... | Answered on Jan 16, 2019
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
E-Machines... | Answered on Nov 22, 2018
E-Machines W3105 PC Desktop Logo
0 questions posted
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W E-Machines
  • W E-Machines
Most Popular Question
need drivers emachines w3115 pci simple
  • Computers & Internet
