20 Most Recent AMD Duron , 700 MHz Processor Questions & Answers
No sound for my pc
if your computer came with a disk the sound drivers could be on it control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers hope this helps
11/30/2010 4:36:37 AM • AMD Duron , 700... • Answered on Nov 30, 2010
I have a AMD processor
Well firstly, your RAM is more than sufficient for multitasking so that's not the problem. You could however do with a slightly faster processor. There is a full list at Wikipedia, this link will take you straight there. I would personally recommend at least a Duron 1100 at 1.1GHz. Because this range of processor is a single core, it will struggle when it comes to multi-tasking. I will however congradulate you on using AMD, I find these to be the best value for money and are great performers.
11/15/2010 7:00:08 PM • AMD Duron , 700... • Answered on Nov 15, 2010
CPU upgrade
Your motherboard has a good support for various Processors. If you want to go for the latest then you can go for Palamino core Athlon 4.Its compatible all the KV7 series boards but all you have to check is "Till WHAT clock speed can your board support?" .
Regards,
Sai.
2/8/2009 8:57:18 PM • AMD Duron , 700... • Answered on Feb 08, 2009
I've tried to install ubuntu+xubuntu on i686 duron 900? 256ram-
Not exactly sure what you are saying... but you DO have a Duron 700? That is 32-bit. No x64 for you!
If that is not what you're saying. You are saying that you received an Xubuntu alternate distro from Ubuntu? Ubuntu comes in prepackaged distributions for i686 (i386, i486)-32bit and x64-64bit.
You can download the Xubuntu for free at
http://www.xubuntu.org/get
Select the Hardy Heron i686 version. When you install, the installer "should" select the best kernel for your system.
7/2/2008 4:53:35 PM • AMD Duron , 700... • Answered on Jul 02, 2008
0answers
How can I get User manual for AMD Desktop Motherboard AM2, DA061L-3D, 48.3BU01.01M, 09178-1M U
I would try the AMD web site. If still available, you will find one there.
6/29/2021 6:50:31 AM • AMD Computers &... • Answered on Jun 29, 2021
I just installed a motherboard because my video went out and the Onboard as well as the video card would not connect. I installed a power supply, new memory, new cpu, new hard drive, new video card and when all that failed still I installed a new motherboard. Still not connecting to the monitor. What am I missing? Here are my specifics. Upgrades Motherboard Foxconn A74ML-K AM2+ AM3 740G Motherboard AMD DDR2 MicroATX SATA PCIe x16 Phenom Video Card Dell ATI Radeon HD 4350 512MB DDR2 PCIe VGA DVI HDMI Graphics Video Card 0P002P Power Supply Apevia BT550W Beast 550W ATX Gaming Power Supply, Supports Dual/Quad Core CPUs Hard Drive Seagate BarraCuda 2TB Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache 3.5-Inch Dvd rom LG Internal 24x Super Multi with M-DISC Support DVD Burner  USB Card FebSmart PCIE 4-Ports Super Fast 5Gbps USB 3.0 Wifi adapter USB WiFi Adapter – 1200M WiFi Dongle High Speed 802.11ac 5dBi Dual Band 2.4/5GHz  Memory LEVEN DDR2 4GB (2GB×2) 800MHz PC6400 Unbuffered Non-ECC UDIMM 240 Pin CPU AMD Phenom II X3 710 2.6Ghz Processor Cpu Cooler Cooler Master CM12V Ultra Silent 8032 Fan Dimensions: 80x80x32 MM Voltage: DC 12V Speed: 2000 RPM Air Flow: 32.5 CFM Noise: 18 dBA Feature: Very Quiet & Long Life Span, Speed Sensor (Tach) Termination: 3-Pin / 3-Wire / 7.5-Inch After my new build would not boot properly I thought it was a video problem and was all ready to rma it. I specifically checked the manual for proper placement of the cmos jumper before I assembled it after reading of other peoples problems with the jumper left in the "clear" position. That's what I get for reading the manual. The jumper was actually placed correctly from the factory. The manual was wrong. -2 eggs for poor documentation and the headaches to find and fix the problem.
Perhaps the monitor is faulty? Did you check that with a device known to work. Listen to Larry though, he is the Hardware Guru here at Fixya.
4/8/2021 11:34:28 PM • AMD Computers &... • Answered on Apr 08, 2021
I have a windows 7 desktop 64bit, amd sempron LE-1200, that reads usb2.0. how do i get it to read a usb3.0 flashdrive without corrupting files when moved on it
USB 2 and 3 are the data speed capability of the interface it is possible to connect a USB3 flashdrive into a usb2 socket all that will happen is the files will transfer slower than on a usb3 socket. Hope this was helpful.
5/14/2020 11:25:53 PM • AMD Computers &... • Answered on May 14, 2020
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
3/20/2019 5:10:23 PM • AMD Computers &... • Answered on Mar 20, 2019
I have an AMD Athlon 64 X2 Dual Core processor running on Windows 7 32 bit. Can I install Windows 7 64 bit oS on this system?
yes but fresh install will be needed.back up important docs first
12/15/2018 8:53:13 PM • AMD Computers &... • Answered on Dec 15, 2018
yes you can. Win 7 win8 win 8.1 are no supported by Microsoft, only win 10.
12/15/2018 8:29:15 PM • AMD Computers &... • Answered on Dec 15, 2018
Hi i just joined and im so clueless what im goin to do amd where and how to statt Please i need your help someone pls! Thank you
on the ask a question page , type in the make , model year, type of equipment and the problem that you have and post it
4/30/2018 5:02:16 AM • AMD Computers &... • Answered on Apr 30, 2018
AMD Duron , 700 MHz Processor Logo
6 questions posted
Top AMD Computers & Internet Experts
Steve
David Shaub
shadow
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AMD Computers & Internet
Most Popular Question
cpu upgrade
  • Computers & Internet
