20 Most Recent Xerox WorkCentre 7556/P Copier Questions & Answers
How do you fix this error on a workcentre 7556 ? 303.777.00
It might be a power issue. If cable etc looks OK, I suggest you download the latest firmware: http://www.support.xerox.com/support/WC7525_WC7530_WC7535_WC7545_WC7556/support/en_US.html?objGUID=12283
3/1/2018 12:31:15 PM • Xerox WorkCentre... • Answered on Mar 01, 2018
Copies come out on the bottom output tray without being set to
check your setting
3/19/2016 9:36:17 PM • Xerox WorkCentre... • Answered on Mar 19, 2016
Invalid login when scanning
go to the webpage of the printer(type IP adres in a webbrowser)Check your scan settingsIs there accounting on the machine?Where are you scanning to?
5/31/2013 3:30:33 PM • Xerox WorkCentre... • Answered on May 31, 2013
Xerox workcentre 3345 paper jam in tray1
If you've modified one of the trays and still encounter the same error, it's worth checking if there are any obstructions in the paper path or if the default paper type and color settings need adjustment. Remove Jammed Paper From Tray 1: First, remove any paper from the Bypass Tray. Grasp both sides of the Bypass Tray and pull it straight out of the printer. Next, pull out Tray 1 until it stops. To remove the tray, lift the front of it slightly, then pull it out of the printer. Check for any jammed paper and remove it. Also, make sure there's no crumpled paper left in the tray or jammed inside the printer. If you have Tray 2 (optional), check it as well. Insert Tray 1 back into the printer and push it all the way in. Fully insert the Bypass Tray as well. Confirm the paper settings if prompted. Try your job again. Power the Printer Off then On: Press the Power/Wake button on the printer control panel. Choose "Power Off" to turn off the printer. Wait for a few seconds, then press the Power/Wake button again to turn it back on. Retry your print job. Replace the Paper Feed Roller (if needed): If the issue persists, consider replacing the paper feed roller. Refer to your printer's documentation for instructions on how to do this. If the problem continues, contact Xerox support.
4/20/2024 9:16:59 PM • Xerox Office... • Answered 3 days ago
Xerox 6204. What is solution to error code 123-315 please?
Question edited for clarity. I found this 123-315 UI Panel Communication Error N 2.2. There is help in the first link but you need to register https://www.google.com/search?q=xerox+6204+error+123-315 ..
3/24/2024 8:05:00 PM • Xerox Office... • Answered on Mar 24, 2024
Error 40b7853c 3T 915 on Xerox Phaser 3300mfp what does it mean?
That means there is no communication. There is a system error that is probably a fatal error. You could try updating the firmware.
2/11/2024 12:50:33 PM • Xerox Office... • Answered on Feb 11, 2024
Where can I find a plastic gear xrx-8x-2sg for a xerox xrx-8x paper shredder, also a diagram
I would ask a friendly Xerox engineer for an OEM one.
12/19/2023 10:24:33 PM • Xerox Office... • Answered on Dec 19, 2023
Code d'erreur 062-395 xerox c60; que fqire?
Fault Code 062-395: Scanner Power Cable Connection Fault or power supply fault.
12/17/2023 7:45:26 AM • Xerox Office... • Answered on Dec 17, 2023
2answers
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support Web page above states: Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB) Manual for free download at link below: Fuji Xerox Color 550 Administrator Manual Page 205
12/5/2023 2:58:24 AM • Xerox Office... • Answered on Dec 05, 2023
Xerox D95 error code 077-313.
Try disabling it. 4112 / D95 families - Fault Code 077-313 : Multi-Feed Sensing Problems. First ... You have the choice to disable the Multi Feed Sensing feature on the machine if you fail to repair the problem or if you have a hard time sourcing the sensor or the board. The NVM Setting code is: 742-268.
4112 / D95 families - Fault Code 077-313 - The Parts Drop
The Parts Drop https://www.partsdrop.com > index.php > 4112-4127-d9...
Fault Code 077-313: Oversize High Capacity Feeder Fault
Xerox https://www.support.xerox.com > en-us > article Sep 21, 2015 - Fault Code 077-313: Oversize High Capacity Feeder Fault · Try these solutions · Did this help?
Error Code Xerox 4112 Error 077-313
Copytechnet https://www.copytechnet.com > ... > Xerox Sep 6, 2019 - Cause: Multi Sheet Check Sensor Actuator loose due to torsion spring disconnected from the arm. Due to improper removal of paper jam at Registration Roll. Jamming Error 077-313 and error 075 - 211 Nov 30, 2016 Xerox 4127 cp error 077-313 Sep 24, 2016 Error Code xerox 700 077-311 Jan 11, 2021 More results from www.copytechnet.com
11/13/2023 12:18:11 AM • Xerox Office... • Answered on Nov 13, 2023
How Do I Reset Counters of Xerox Workcentre 7435 Toner Chips ?
You can't. It is hard wired in programmed memory. The reason is because most Xerox printed are supplied on a consumables deal where you have to buy toner direct at a slightly inflated price to cover the lowered lease cost of the machine. These machine also 'phone home' for interrogation..
9/14/2023 6:21:28 PM • Xerox Office... • Answered on Sep 14, 2023
Error code 116-323 in xerox 250
error code 116-323 on a Xerox WorkCentre 250 series printer typically indicates a problem with the Transfer Belt Unit. This unit is responsible for transferring the toner from the imaging drum onto the paper during the printing process. Here are some steps you can take to troubleshoot and potentially resolve the issue:
  1. Power Cycle: Turn off the printer and unplug it from the power source. Wait for a minute or two, then plug it back in and turn it on. Power cycling can sometimes clear temporary errors.
  2. Check Transfer Belt: Open the printer's front cover and locate the Transfer Belt Unit. Ensure that the Transfer Belt is installed correctly and that there are no visible signs of damage or obstruction.
  3. Clean the Transfer Belt: Dust and toner particles can accumulate on the Transfer Belt, affecting its performance. Gently clean the Transfer Belt with a soft, lint-free cloth or a cleaning pad designed for this purpose.
  4. Reset Printer: Some printers have a reset option or a combination of buttons to clear error codes. Refer to the printer's user manual or Xerox's support documentation for instructions on how to reset the printer.
  5. Update Firmware (if applicable): Check if there are any firmware updates available for your Xerox WorkCentre 250 printer. Updating the firmware might address known issues and improve printer performance.
  6. Check Consumables: Verify that all consumables, including toner cartridges and imaging drums, are correctly installed and not depleted. Replace any depleted consumables with new, genuine Xerox supplies.
  7. Check for Paper Jams: Ensure there are no paper jams or obstructions in the paper path that might be causing the error
8/6/2023 12:52:07 PM • Xerox Office... • Answered on Aug 06, 2023
Fuji Xerox ApeosPort-IV C4430. It has 116-331 fault code error. Any assistance to remove and get it done??
Question edited for clarity. Power Cycle it.
Fault Code 116-331
Xerox https://www.support.xerox.com > en-us > article Jan 19, 2021 - Power off/on the printer. For details, refer Power Off the Printer Using the Power Switch. Wait Two Minutes and Then Power On the Printer. Missing: C4430 ‎' Show results with: C4430
Thread: Error 116-331
Copytechnet https://www.copytechnet.com > ... > Xerox Jan 20, 2012 - Hi, 1. Check and reset all connectors on ESS PWB and HDD. 2. Press and hold the 4, the Stop, and the Power Save buttons on the Control Panel ... Xerox workcenter 5225 show error code 116-331 Sep 10, 2019 Dead Machine 242 code 116-331 Sep 10, 2019 WC 6515 Error 116-331 Jun 6, 2019 xerox workcentre 5225 116.331 error code Sep 6, 2012 More results from www.copytechnet.com Missing: C4430 ‎' Show results with: C4430
Need urgent help with Error Code 116-331! It's a PrimeLink ...
Reddit https://www.reddit.com > Xerox > comments > need_u... Nov 26, 2022 - 116-331 is usually just a corrupted job. Power off the machine using the button behind the front door. (not the button on top). Press and hold # ...
7/21/2023 11:11:11 PM • Xerox Office... • Answered on Jul 21, 2023
2answers
Xerox DocuMate 4790 Color Duplex Document Scanner. What is F63 error please?
First try to Reset the scanner and computer: 1. Turn off the scanner power. 2. Unplug the USB cable and power from the scanner. 3. Reboot (restart) the computer. 4. Plug the USB cable and power cable back into the scanner. 5. Turn the scanner back on.
7/4/2023 3:49:47 PM • Xerox Office... • Answered on Jul 04, 2023
How to solve 003-319 ERROR - RAP IIT Video Driver Detection Fail in xerox 7435
The 003-319 error on a Xerox 7435 indicates a Video Driver Detection Fail. This error typically occurs when there is an issue with the video driver or the communication between the video driver and the machine. Here are a few steps you can take to try and resolve the issue:
  1. Power cycle the machine: Turn off the machine, wait for a few seconds, and then turn it back on. Sometimes, a simple power cycle can resolve temporary communication errors.
  2. Check video cable connections: Ensure that the video cable (usually a VGA or HDMI cable) is securely connected to both the Xerox 7435 and the device it is connected to (such as a computer or a server). Disconnect and reconnect the cable to ensure a proper connection.
  3. Verify video input settings: On the Xerox 7435 control panel, navigate to the video input settings. Ensure that the correct video input source is selected, corresponding to the connected device. If the wrong input source is selected, it can lead to a video driver detection fail.
  4. Update or reinstall video drivers: If possible, update the video drivers on the device connected to the Xerox 7435. Visit the manufacturer's website or use appropriate software to download and install the latest video drivers. If the drivers are already up to date, you can try reinstalling them to ensure they are properly installed.
  5. Perform a firmware update: Check the Xerox website for any available firmware updates for your Xerox 7435 model. Updating the firmware can resolve known issues and improve compatibility with video drivers.
7/2/2023 2:52:35 PM • Xerox Office... • Answered on Jul 02, 2023
124-374 fault when running black copies
  1. Restart the device: Power off the printer, wait for a few seconds, and then power it back on. Sometimes, a simple restart can resolve temporary errors.
  2. Check toner levels: Ensure that the black toner cartridge has sufficient toner. If it is low or empty, replace it with a new cartridge.
  3. Clean the imaging unit: Open the printer's front cover and carefully remove the imaging unit. Gently wipe the surface of the black imaging unit drum with a soft, lint-free cloth. Avoid touching the drum with your hands. Reinstall the imaging unit securely.
  4. Perform a firmware update: Check if there is a firmware update available for your printer model on the manufacturer's website. If an update is available, follow the instructions provided to update the firmware. Firmware updates can sometimes fix known issues and improve overall performance.
  5. Check for paper jams: Open all access doors and paper trays and inspect for any paper jams or obstructions. Remove any stuck paper carefully. Ensure that the paper path is clear and that the paper is loaded correctly in the trays.
  6. Reset the printer to default settings: Access the printer's settings menu and look for a "Restore Defaults" or "Reset" option. Performing a factory reset can help eliminate any incorrect settings that may be causing the issue.
6/28/2023 2:37:03 AM • Xerox Office... • Answered on Jun 28, 2023
Xerox WorkCentre 7556/P Copier Logo
6 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
fix error workcentre 7556 303 777 00
  • Office Equipment & Supplies
