20 Most Recent
Elo 1525L 15" LCD Monitor Questions & Answers
My screen is black except for a white line near
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
hi-
Remove the monitor and try it on another pc with xp or better. If it is working you have pc problems - remove all the ram and reinstall one stick at a time.
if that still doesn't fix it - please come back and fill me in
I hope this works for you - please vote me up.
Thanks
RICESKI
Cannot align touchscreen properly.
yes it may possible that a spike may came and damaged the sensitive chip you are been advised to attact spike arrester and surge suppreser before the computer replace the synaptic ic inside the device problem will be solved
I can not hear any sound through the speakers of
The Elo ET1527L Monitor has stereo speakers. Within the OSD (On Screen Display) you can control several properties of the monitor like; brightness, contrast, positioning, color, and SOUND. See the buttons on the right side.
I recommend setting the sound to 100%. The speakers are small and weak. They are pointed to the rear, I assume for customers to hear.
The buttons do have a lock-out feature too. If they don't respond, while on, hold down the top two buttons and the screen should display Lock / Unlock. Wait until you see the one you want and then release. The power button lock out works the same way, holding top and 3rd button to lock/unlock.
The device drivers give you an option to use internal (monitor beeps) and external (PC port) sound sources.
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
