20 Most Recent
Rosen G8 CV8090 Car DVD Player Questions & Answers
Won't come on
check the fuse boxunder the hood. Use a standerd auto light tester. If there is light its good.
Every little bump causes loss of signal
it obviously has some loose or intermittent problem inside the unit. I'm presuming that the external power plug is secure. You said that it was unwatchable so what do you have to loose by sending it away for repair? If you don't want to spend the money repairing it or the repair isn't covered by warranty. Get a new unit and enjoy the warranty. They are always improving these units as time goes on.
Wireless functionality
I noticed my Rosen player had an antennae wire for the headphones on the top of the player. You could check to make sure the antennae wire is connected.
How do I order replacement accessories (remote, headphones, game controller) for the Rosen XR1020 overhead dvd system?
A few options:
You can contact the manufacturer, VOXX Electronics, by phone at 1-800-645-4994 or by email at
[email protected]. They may be able to provide you with the accessories you need or direct you to an authorized dealer.
You can visit the VOXX Electronics website and look for the XR1020U model, which is the same as the XR1020 but with a universal trim ring. You can find the list of accessories and their part numbers on the product page. You can then order them online or call the customer service number above.
You can search for the accessories on online marketplaces such as eBay, where you may find new or used items for sale by other users. However, you should be careful to check the seller's ratings, reviews, and return policy before making a purchase.
Rosen roof dvd player has sound but no picture please help
Hi Gill.
Check, Make sure the cables are connected. Try cleaning the laser and the DVD. Make sure the TV is on the correct input.
try swapping one of the sound cables to see if the yellow cables is in fact damaged.
1) Plug the DVD player in to the TV that it does work on. Make sure there is no disc in the player. Check the DVD players set up menu. Look in the Picture menu and change the output to "RGB" Move the player back to the TV/VHS Combi. Select the input that gives you RGB1.
2) Same as above, but this time change the Picture menu to PAL (or composite or Video....whatever is the other option name that
isn't RGB or S-Video). Retest on the Combi, but this time you want AV1.
If these don't work then you might need to have a look in the TV manual about connecting external sources. It could be that because the combi has a recorder that it's trying to stop you from copying DVD to VHS. See if there's an input on the combi that bypases the recorder.
Read more:
https://www.diynot.com/diy/threads/dvd-problem-sound-but-no-picture.211588/#ixzz5FYrJiX6o
I found all this on the internet so not sure if it will help you out.
or try this link.
dvd player has sound but no picture Google Search
