20 Most Recent
Biostar GEFORCE 6100-M9 Motherboard Questions & Answers
Can i change my 32
32Bit/ 64Bit is the respective capacity of the motherboard hardware for data flow within the motherboard and its components and it can not be changed.
Hope this helps! Good Luck!
CreativeTECH
I need to reinstall windows cause its corruped i
You will have to reset the BIOS to factory. To do this, you will have to open the case and expose the motherboard. The motherboard will have a set of pins that when touched together, it resets the bios and wipes the password. You will have to locate this set of jumpers and short them.
Look at a map of the board, and look for the reset jumpers here:
ftp://ftp.biostar-usa.com/manuals/GEFORCE%206100-M9/GeForce%206100-M9_BIOS.pdf
If you can not find the reset jumpers, you can just take out the battery on the motherboard. It is silver, round and the size of a quarter. A simple clip holds it in place. remove it and put it back in.
Then put it all back together, and reboot. press the del key or F1 key durring the begining of the boot cycle and you will be able to able to access the BIOS to change the boot sequence.
MS-6378X-L 512 Ram not working.
1. this may be due the manufacturer or your mounting of the RAM itself. It is hard to tell from what you have described.
2. Some RAM sticks may not be built for you PC and take particular brand or configuration which your manufacturer of the PC will point out in the installation manual that came with you PC or Motherboard ( if you built the PC yourself)
3. Sometimes there is a hardware conflict when upgrading new hardware in an older PC.
4. there is also the contacts in a PC that have not been cleaned properly that will result in an failed installation of a device.
5. Some Mother board manufacturers only 2 require sticks of ram as opposed to 1 stick in a particular motherboard for proper operation.
6. check your manufactures site for the proper ram sticks to upgrade your motherboard with.
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
