20 Most Recent Envision H191W Monitor Questions & Answers
turn of the monitor then press the menu
Envision H191W... | Answered on Jan 03, 2013
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Envision H191W... | Answered on May 09, 2011
You need to set your PC video resolution to the monitor native resolution. Please read below.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Envision H191W... | Answered on Feb 01, 2011
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Envision H191W... | Answered on Jan 12, 2010
Page 5 in your users manual : 6 settings you have 45 seconds to push exit button to save. I have had times that when changing computers that I have had to disconnect the video cable, power down the monitor and computer, power up the monitor with nothing connected to re-set it, power everything down, reconnect monitor, and restart the system. Most times the H191W will detect everything If you need a manual
www.envisiondisplay.com or 1-888-838-6388 can help you. I have used this monitor for several years and think its one of the best. The technical support should help you. Hope I helped.
Envision H191W... | Answered on Aug 23, 2009
Are you running DVI or AGV? Try swapping from one to the other if it possible.
Is it a possible resolution notifier? My old LCD did that just to tell me what is what. Annoying as hell but I couldn't turn it off.
I can suggest turning the resolution down a level. See what happens there. Or possibly the refresh rate.
Envision H191W... | Answered on Jul 09, 2009
Try to see if you got a button that is sticking.. 9 times out of 10 that is the solution but if not you might have a bad controller board in the monitor itself that may need to be replaced..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Envision H191W... | Answered on Apr 21, 2009
Envision H191W Monitor Logo
16 questions posted
Top Envision Computers & Internet Experts
Kelly Blanc
Kelly Blanc
Level 1 Expert
Ekse
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Envision Computers & Internet
Most Popular Question
osd locked envision monitor
  • Computers & Internet
