20 Most Recent Fellowes Powershred C-120 Strip-Cut Shredder Questions & Answers
POWERSHRED C-120 CONTINUES RUNNING WHEN NO PAPER TO SHRED
Best answer is to check the Fellowes FAQ. It's an easy fix. Shredder Running Continuously
3/14/2015 2:33:48 AM • Fellowes... • Answered on Mar 14, 2015
2answers
What is the fiscal size of Fellowes shredder?
Question edited for clarity, spelling of 'Fellowes'. I don't think 'fiscal' means what you think it means? ============================================= fis·cal /?fisk(?)l/ adjective
  1. relating to government revenue, especially taxes. "monetary and fiscal policy" ========================================= Fellows does all sizes of shredders up to Office Quality machines that will also Crosscut shred credit cards and CDs. https://www.google.com/search?q=Fellowes+shredders ..
4/14/2024 7:12:35 PM • Fellowes Office... • Answered on Apr 14, 2024
Gears for a fellowes p45c shredder. The gear I need is 35mm in diameter with 41 sloping teeth. The other 7 teeth are on a shaft that is 15mm long and 12mm diameter. Total length of the gear is 28mm.
I found a website called shredderparts.com that sells replacement parts for Fellowes paper shredders, including gears, switches, and spare parts for the cutting head. Unfortunately, I could not find a gear with the exact specifications you mentioned. However, they do have a 39 tooth second stage drive gear that is compatible with the Fellowes P-45C shredder. They also have a 41 tooth 7 tooth primary drive gear that might be compatible with your shredder. You can contact them at 1-800-634-9329 to check if they have the gear you need in stock.
1/24/2024 2:59:38 AM • Fellowes Office... • Answered on Jan 24, 2024
I need a replacement bin for my PS70 FELLOWES shredder, where can I purchase one?
Fellowes PS70-2 36170 Paper Shredder Waste Collection ...
Get That Part https://www.getthatpart.com > fellowes-ps70-2-36170-pa... Fellowes PS70-2 Paper Shredders SPARES - REPAIRS - UPGRADES GENUINE OEM Fellowes Parts 36170-PB Waste Collection Bin NO EXCHANGE REQUIRED ! US$55.00
11/4/2023 4:43:03 PM • Fellowes Office... • Answered on Nov 04, 2023
2answers
How can I open a Fellowes Venus 2 125 Laminator as I have a small pouch stuck in it and it won't come out
I had this happen where I worked and I elected to fix it. You have to remove the screws in the base, and IIRC the ends. Then I used a knife to cut the laminate pouch and pull out the pieces with pliers. If you can turn it on without damaging the machine or zapping yourself, the heat will help. My boss ordered a replacement which turned up a few days later :>D https://www.google.com/search?q=Fellowes+Venus+2+125+laminator+jammed ..
1/21/2023 10:54:43 PM • Fellowes Office... • Answered on Jan 21, 2023
2answers
Can I run goo gone through my paper shredder to clean stickiness without dismantling it?
Yes you can, you can also spray it with WD40, leave it an hour, spray it again and run a few sheets of plain paper through it. WD40 is kerosene based.
11/15/2022 2:26:17 AM • Fellowes Office... • Answered on Nov 15, 2022
Powershred 99Ci. Does it have a reset button?
No, but there is an interlock that ensures the collection bin is fully inserted. https://assets.fellowes.com/manuals/99Ci_409366%20090215%20FS%201L.pdf
12/31/2020 5:19:00 PM • Fellowes Office... • Answered on Dec 31, 2020
Our Fellowes C480 will not pull the paper in to shred. The motor runs and sounds normal, but the paper doesn't feed in. Any suggestions?
More than likely your gear is stripped. Depending on what you paid for it it might not be worthwhile.
9/2/2019 7:53:25 PM • Fellowes Office... • Answered on Sep 02, 2019
2answers
Can i get a replacement gear for my fellowes p-45c shredder?
https://www.getthatpart.com/fellowes-p-45c-paper-shredder-oem-39-tooth-second-stage-drive-gear.html
8/13/2019 6:17:07 PM • Fellowes Office... • Answered on Aug 13, 2019
Can i get a manual for a Fellowes PS 72c5 ?
You can find a free manual for it here: https://www.fellowes.com/us/en/support/manuals-downloads.aspx
4/19/2019 8:32:48 AM • Fellowes Office... • Answered on Apr 19, 2019
Fellowes Powershred C-120 Strip-Cut Shredder Logo
2 questions posted
Top Fellowes Office Equipment & Supplies Experts
George Mclaughlin
Grand Canyon Tech
Grand Canyon Tech
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Fellowes Office Equipment & Supplies
Most Popular Question
powershred c 120 continues running when
  • Office Equipment & Supplies
