20 Most Recent
Ricoh Aficio Mp5000 Lanier Ld050 Questions & Answers
Error message sc.440 on ricoh mp4000 copier
It happen when there is a slight load tansfer belt. What l did was..clean all the rollers & bushings underneath the transfer belt. Threre are 3 rollers..4 bearings & 2 bushings. Remove all stains.. And also you could polish the surface of the transfer belt by using car polish liquid to smoothen the belt rotation
The toner end show even there is new toner in the machine
Look up your model on Google and search for the reset sequence... It is usually a combination of button presses that will cause the machine to acknowledge that there is a new toner cartridge in the machine. Normally a new toner cartridge should trigger this reset automatically but in some cases you may need to do it manually. If you cannot find the information you need on Google then call the tech-support line for your particular printer manufacturer... They should be able to help you for free... Just make sure to tell them that you are using a THIER brand of toner cartridge (otherwise they will simply blame it on the generic nature of the toner cartridge).
I have 200 problem for code sc542
Fusing temperature warm-up error The fusing temperature does not reach the fusing standby temperature of 45oC (113oF) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50oC the fusing roller does not reach warm-up temperature.
What is the solution of error code sc220
Sc 220. For the earlier model..it refers to the polygon motor error. U cannot clean the motor. U have to replace it. Becauce the sensor did not detect suficient optimal RPM
Code sc542
check the fusing unit, check thermistor,thermostat heater lamp if busted.
Error code sc878-01
Try to remove the hdd. Does the sc code disapear? Replace the hdd if needed
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
