20 Most Recent Craig CTV-41304 13" TV Questions & Answers
2answers
The remote won't work. Battery's are good.
Hello
You just check if your remote control hanset emits infrared light. There is an infrared light emitting diode, an LED [Light Emitting Diode], in front of your remote control hanset, from which that rays goes to the infrared sensor inside your TV, which in turn receives it and processes it. You can check its emission. You may have a cellphone with camera option. Set it to camera positon and face your remote controls' LED towards its lens, at a distance of say 1 feet or so, just press all keys one by one and see whether there is light comes from it or not. Your cellphone camera will sense it and you can see its image on its screen. If not, your remote handset is not working. Check its battery contacts for any dirt or rust, that prevents proper battery contacts. If it is Ok, just open it, it is snap fitted and you can open it. Check whether there is any loose solderings on the leg soldering of the above said LED, or a crystal used inside it. If all are ok, you have to replace the remote handset. OK.
1/5/2012 7:34:57 PM • Craig CTV-41304... • Answered on Jan 05, 2012
I'm trying to hook the TV up to the cable
The incoming cable should simply connect to the antenna/cable connector on the back of the TV. It's a standard connector. Normally you just need to connect the cable to the TV, then set the TV for "cable" through the on-screen menu using the TV remote or front panel buttons. However, the tuner in the TV may not be compatible with your cable system. Depending on the age of the set and type of cable system, the set may only work if you use a cable converter box from the company. If you have the cable connected and the set can't find any channels, this may be why.
8/6/2011 1:30:39 AM • Craig CTV-41304... • Answered on Aug 06, 2011
Geat picture no sound from
Make sure that the sound output connectors (the red and white ones) are correctly plugged in (the colours corresponding at both ends of the 3-headed cable) and that the sound volume in the ATT box is almost to the max.
7/27/2011 3:31:19 PM • Craig CTV-41304... • Answered on Jul 27, 2011
Black screnn with sound
Are you using a cable box? If so, what kind of cable do you have going from the box to the TV?
2/28/2011 6:58:40 PM • Craig CTV-41304... • Answered on Feb 28, 2011
When requared product are lanch ctv lcd etc
your fuse went bad in tv.
2/16/2011 3:53:41 PM • Craig CTV-41304... • Answered on Feb 16, 2011
How do you delete unwanted channels form the
one way is to re scan your channels from the menu option but choose the manual channel search that way you can choose exacltly the channels you want.
4/15/2010 4:28:14 AM • Craig CTV-41304... • Answered on Apr 15, 2010
I dont know to hook up vcr to a criag 15 inch tv.
do you have av plugs on the tv? if so use the av wire jumpers white to white,yellow to yellow, red to red
2/14/2010 6:51:43 PM • Craig CTV-41304... • Answered on Feb 14, 2010
Craig model CLC512 is stuck on video scrambled.
Power cycle it for 10 minutes. This is not a good make and is built on lowest price point for the components. https://www.google.com/search?q=Craig+model+CLC512 ..
1/28/2024 11:51:18 PM • Craig Televison... • Answered on Jan 28, 2024
2answers
I have an older CRAIG TV set and it has a FACTORY lock on it... how do i get rid of that?
Download the user manual to your set and refer it. It will have details.
1/17/2024 10:56:01 PM • Craig Televison... • Answered on Jan 17, 2024
I can't figure out which buttons to push & in what order to play a CD on my Craig CR41470A
Usually press the Mode button for CD, and then press the Play button which is usually a right facing triangle. Similar manuals https://www.google.com/search?q=Craig+CR41470A+manual ..
12/24/2023 3:31:57 AM • Craig Televison... • Answered on Dec 24, 2023
Craig CVD401A-BLS Compact HDMI DVD Player. It powers off immediately and won't open disc drive.
Question edited for clarity, (make model (what it is)'. Question moved from Power Computers. cheap as chips, low quality and not worth fixing. You can get a new one for $16. It has a power IC issue. Read the Reviews! https://www.google.com/search?q=CVD401A-BLS ..
1/29/2023 12:36:35 AM • Craig Televison... • Answered on Jan 29, 2023
Craig sound at connecting without remote to phone
Question doesn't make much sense as it has no punctuation and not enough details. No model details, or even it is a television. All devices need a remote especially if it is a television. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/8/2022 11:37:36 PM • Craig Televison... • Answered on Dec 08, 2022
Craig 15" LCD TV the HDMI input does not work
check an d test cable first if good will need a multi meter to test port and circuit or send out to repair shop
5/11/2021 6:58:09 PM • Craig Televison... • Answered on May 11, 2021
I have a clicker Universal remote, and I want to know the code to my Craig converter box.
Use code search on your Clicker URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
12/26/2020 2:07:02 AM • Craig Televison... • Answered on Dec 26, 2020
Can I set clock on Craig cht923 soundbar without remote?
The remote control would make an easier task.
12/12/2020 7:53:24 PM • Craig Televison... • Answered on Dec 12, 2020
Televison & Video Logo
Popular Tags
15 questions posted
Top Craig Televison & Video Experts
Paul Bade
 Grubhead
Grubhead
john h
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Craig Televison & Video
Most Popular Question
remote work batterys good
  • Televison & Video
