20 Most Recent Akai PDP-5016H 50 in. HD-Ready Plasma Television Questions & Answers
I have an AKAI 50"
Maybe the plasma controllers are gone.
10/18/2017 10:55:32 AM • Akai PDP-5016H... • Answered on Oct 18, 2017
0answers
No display r sound
I can tell you exactly which 3 dollar part to replace . But i put my time into my education and if i just tell you for free my kids will go hungry.
11/16/2013 8:35:58 PM • Akai PDP-5016H... • Answered on Nov 16, 2013
Tv background noise
Try by resetting the picture settings. Brightness, contrast etc. Do a factory reset. Refer its user manual for details.
3/22/2013 5:02:32 PM • Akai PDP-5016H... • Answered on Mar 22, 2013
Only get the bottom half of screen with good picture, top is color lines.
Its a Plasma so it likely has 2 sustain boards--one for top half of screen and another for the bottom. Some brands use different names but this is likely the issue here.
4/24/2012 12:43:27 AM • Akai PDP-5016H... • Answered on Apr 24, 2012
Tv want turn on turn off an on
Replace power supply. Try Encompss Parts, or Shop Jimmy
11/28/2011 6:30:16 AM • Akai PDP-5016H... • Answered on Nov 28, 2011
How can i get my sound or audio to come out
Go to the menu and make sure the speakers on is selected.
11/16/2011 9:22:17 PM • Akai PDP-5016H... • Answered on Nov 16, 2011
I have an AKAI PDP
Hello
Your suspection may be correct. But this type of fault will occur due to faulty system memory IC too. First replace it. Then proceed. It seems you to be a well experienced technician. Replace the EEPROM first. OK.
6/19/2011 6:49:23 PM • Akai PDP-5016H... • Answered on Jun 19, 2011
Is there an spdif plug
Sorry - no digital audio input / outputs (spdif, optical, coaxial, etc.) on this TV. Standard analog "RCA" type audio connections only.
AV Input & Output RCA Terminals
S-Video Input Mini Din 4 Pin Terminal
1 Set of Left and Right Stereo RCA Terminals:
Audio Input for D-Sub 15 Pin & DVI Connector
Audio Input for S-Video
Audio Input for YCbCr
Audio Input for YPbPr
I hope this helps. Please rate my reply - thank you.
2/23/2011 9:46:18 PM • Akai PDP-5016H... • Answered on Feb 23, 2011
0answers
2answers
I just bought a blu
If you have it plugged into the dvi that most likely is the highest resolution 1024x768.
Thank you,
Lee
8/21/2010 10:51:18 PM • Akai PDP-5016H... • Answered on Aug 21, 2010
2answers
Akai pdp5016h....turns on with main power switch,
Does the screen turn on momentarily before it goes into standby mode? Do you hear clicking noise before it goes into standby? Please answer these questions so that I can help you with your problem.
Sai.
8/16/2010 12:58:32 AM • Akai PDP-5016H... • Answered on Aug 16, 2010
2answers
Akai lct 2715 the power
Hi
Thanks for using FixYa. This light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/30/2010 1:14:41 AM • Akai PDP-5016H... • Answered on Jun 30, 2010
When i turn it on their is nothing just the light
The flashing red light is an error code to diagnose what is wrong with it. Turn off the TV and then turn it back on and count the series of flashes, make a note of it, and re-post with that number along with the rest of your TVs information again. It is the beginning of the repair process.
I hope this helps and good luck!
2/1/2010 5:02:30 AM • Akai PDP-5016H... • Answered on Feb 01, 2010
2answers
My TV reboots at any giving time.. Most of the
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. X, Y sustain, buffer boards controls picture, fires the gas, and many others functions. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged/leaky capacitors on these boards and replace whichever has gone bad. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
1/19/2010 3:28:42 PM • Akai PDP-5016H... • Answered on Jan 19, 2010
Plasma screen has thin black line from left to right
ALL the SUSTAIN PC BOARDS are N/A, parts of the PLASMA PANEL UNIT (N/A)
12/31/2009 7:58:24 AM • Akai PDP-5016H... • Answered on Dec 31, 2009
Akai PDP-5016H 50 in. HD-Ready Plasma Television Logo
Popular Tags
60 questions posted
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
tv comes but no picture
  • Televison & Video
