20 Most Recent
Fusion FEW12PK Car Subwoofer Questions & Answers
Hello i have a Fusion
RJ12 6P6C to RJ12 6P6C Cross Over Cable Plug (RJ11 6 wire) BLACK 3m
The cable you need is above you will probs need a 5 metre cable if it's in your boot they cost about 3 to 5 pounds online.
My sub has power, but no bass, why
The speaker coil is probably blown. Measure the coil with an Ohm meter and see if you get a low resistance reading - if you don't get any reading, then it's blown.
Not getting power when ignition is on and what is
the rem input (probably a blue wire) is what tells your amp to come on. the power supply is the red wire, that means that the amp is powered. it is not 'on' until the remote (rem) wire is powered. It acts like a power button or switch that is controlled by your unit. there are ways around conventional wiring if you have trouble getting your unit out.
I have brought and wired
The blue remote lead hooks up to your stereo head unit in the dash...when you turn the radio on the remote lead becomes hot(+12V) to turn the amplifier on...without the remote lead the amplifier would stay on all the time and would then drain your battery...the blue lead is a turn on signal sent tot the amp
When i turn up the volume the base cuts out and
Check and re check the grounds. You need a good solid ground. Sound simple, but we always seem to overlook the obvious... or Possibly the deck has a high output(rms watts) and is overpowering the inputs on the amp. In this case use a line out converter.
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Subwoofer rumbling noise
check all your supply wiring's specially the one that is connected directly to the positive terminal of your battery, it has to be of enough gauge to supply your amplifier's wattage, and it is has to be properly grounded to the body of your car.
Sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
