20 Most Recent Mag Innovision LT561D PNP Monitor Questions & Answers
Simply try replacing ALL the large Value Electrolytic Capacitors on that board, 1000uF, 470uF, 330uF, 220uF, they are "the big fat round blue things" marked with say 1000uF 16Volt or the like, get the EXACT same ones and replace them... this may indeed fix ya uint. Good luck.
Mag Innovision... | Answered on Jul 24, 2007
Take 4 screws from bottom and slide ( silver ) front frame up to unlock ( bayonet ) style. to continue disassembly, remove 6 screws 3 left and 3 right to take off screen. Next is the cover for 2 boards 1-power board and 2-main board. You can now repair or replace both boards.
Mag Innovision... | Answered on Apr 25, 2015
Considering your file is a media file you should go for digital media recovery software. I can suggest you few, must try Stellar Phoenix (http://www.stellarinfo.com/mac-photo-recovery.htm), Disk Drill (http://www.cleverfiles.com) and Wondershare (http://www.wondershare.com/data-recovery/)
Mag Innovision... | Answered on Apr 03, 2014
Dumb question, but do you have the audio cable hooked up from the monitor to an audio output on your computer, volume up, mute turned off.
Mag Innovision... | Answered on Jan 27, 2013
check the cable connected to the monitor
run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
Mag Innovision... | Answered on May 23, 2017
wal-mart or best buy. In the area of wall mounts. good luck.
Mag Innovision... | Answered on Oct 25, 2014
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
Mag Innovision... | Answered on Apr 20, 2014
whatever the manufacture says it is
Mag Innovision... | Answered on Nov 24, 2013
Computers & Internet Logo
1 questions posted
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Thomas F. Schneider
martin hogg
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LT Mag Innovision
  • LT Mag Innovision
Most Popular Question
mag lt561 lcd monitor
  • Computers & Internet
