20 Most Recent Mag Innovision InnoVision XJ 700E Monitor Questions & Answers
Please check the Bobbin Winder.
If the Bobbin Winder shaft is moved to the right position (bobbin winding mode), the needle will not move.
Please return the Bobbin Winder shaft to the left position and press the Start-Stop Button or Foot Control to start the machine in the sewing mode.
Mag Innovision... | Answered on May 14, 2011
check the cable connected to the monitor
run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
Mag Innovision... | Answered on May 23, 2017
wal-mart or best buy. In the area of wall mounts. good luck.
Mag Innovision... | Answered on Oct 25, 2014
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
Mag Innovision... | Answered on Apr 20, 2014
whatever the manufacture says it is
Mag Innovision... | Answered on Nov 24, 2013
It is possible that you have connected two cables from Monitor to CPU,
We need to check if there's a cable that has blue connector (VGA) and another that is HDMI(may be black in color) or DVI (white connector).
In case there are two cables that go from the monitor to the computer tower I would suggest you to removing one of the cables will resolve the issue.
Feel free to revert for any further assistance
Mag Innovision... | Answered on Mar 11, 2013
yes you can use those button to adjust the brightness. just press one of the button then it will appear the set up and adjustment.
Mag Innovision... | Answered on Oct 08, 2012
Computers & Internet Logo
2 questions posted
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
ThaMp3Doctor
ThaMp3Doctor
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XJ Mag Innovision
  • XJ Mag Innovision
Most Popular Question
ve brother innovis 700e recently
  • Computers & Internet
