20 Most Recent EZ Dupe GS4SAMB 4 Copy DVD/CD Dupicator Features 22x Black Samsung Dri Questions & Answers
Check device manager for errors with the drive. If you place a data disc in the target drive does it read the contents?
EZ Dupe GS4SAMB... | Answered on Aug 31, 2014
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
EZ Dupe... | Answered on Apr 20, 2016
Hello
I am assuming it's an internal drive for a PC and not a Laptop.
Here is a nice illustrated guide to install an older IDE version:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=lpg40238&lc=en
For Sata you don't need to configure any jumpers just connect the Sata cable to the spare port on the motherboard and the other end to the drive also don't forget to connect the power cable too.
you cannot connect IDE cable to Sata and vice versa.
Hope this helps.
EZ Dupe... | Answered on Mar 01, 2012
I would suggest uninstalling the software, reinstalling it and then making sure that you have all of your updates on the software and the firmware updates on the DVD drive.
EZ Dupe... | Answered on May 12, 2011
ez dupe is not the best program for burning dvds and it may well be a setting in the program that you have missed
EZ Dupe... | Answered on Aug 07, 2009
going to buy a new machine might be cheaper in the long run . Thanks.
EZ Dupe... | Answered on Dec 16, 2008
If your touchscreen isn't responsive or not working how you would expect, try restarting your PC. If you're still having problems, check for updates: ... In Settings, select Update & security , then Windows Update , and then select the Check for updates button. Install any available updates and restart your PC if required.
https://support.microsoft.com/en-us/help/4028266/windows-10-what-to-try-if-your-touchscreen-doesnt-work
Computers &... | Answered 15 minutes ago
A blinking WPS on the router usually means it is actively waiting for a device to connect. For security reasons, it is best to set a time limit for how long WPS pairing can remain active in the router, or to turn WPS off completely and connect only with a standard WPA/WPA2 security key.
Once a device is connected via WPS, it is as secure as if it was connected with a standard security key. WPS is only there as a way to make connecting to routers easier with a shorter password that is supposed to only work for short time while WPS pairing is enabled. ALL OTHER TIMES, WPS SHOULD BE TURNED OFF!
Computers &... | Answered 2 hours ago
EZ Dupe GS4SAMB 4 Copy DVD/CD Dupicator Features 22x Black Samsung Dri Logo
1 questions posted
Top EZ Dupe Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EZ Dupe Computers & Internet
Most Popular Question
telex spinwise
  • Computers & Internet
